Chris NottSky Insurance
Results 1 to 12 of 12
    Dec 2006
    131
    1.8t aeb inlet pipe?
    the small pipe maybe 10mm next to the throttle body, what does it connect to? same for the 10mm(ish) pipe underneath the throttle body, whats that for? thanks
    Aug 2010
    1,540
    picture?
    Dec 2006
    131
    not my pic but to the right hand side of where the throttle body bolts on theres a pipe pointing towards you, that 1 and a 1 underneath too. cheers
    Dec 2006
    131
    anyone?
    Dec 2006
    131
    on the crankcase breather there is a t peice. does the small pipe go to the inlet manifold with the check valve inline?
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    picture not working mate
    it might go there, others will come along with the answer. im runnin a tdi the now and not looked at my aeb motor for over a year so cant remember now.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,318
    not sure about a 10mm pipe?
    Theres a big outlet on top perhaps 20-25mm which goes to the pancake valve, then one underneath thats for the dump valve recirculation. Perhaps theres also a small one for the N75?
    For the crank breather, theres a T-Piece attached to the Z pipe, with a check valve then a small hose up to the underside of the inlet manifold. The only other connection i can think of on the manifold is the front left corner of the plenum, which has a small nipple takeoff for the dump valve.
    TD5 Land Rover Defender build
    Dec 2006
    131
    the hose from the t-piece to inlet is 1 of the 1s i was talking about, so thats that 1 sorted, where does the charcoal canister vent from/too on aeb? i think that is probably going to be my spare pipe just to the side of the throttle body ??
    Aug 2010
    1,540
    theres a few pipes round there. need a pic really....... the carcoal canister (vent from the petrol tank) will go to the inlet system somewhere.
    any split/soft hoses/the one way valve in the beather system being gunked up.......... will need replacing as they'll be letting in fresh air in/venting fresh air/causing excess crankcase pressure/subjecting the crankcase to too much vacuum/causing the air mass sensor to be reading wrong.... and will be causing engine lights to be on/causing running faults etc.
    need a picture of the pipe your on about to have any idea.
    Dec 2006
    131
    "Stick a V8 in it!"
    15,318
    One on the left with the rubber pipe goes round to the N80 valve etc, one on the right goes to the breather T piece via the check valve.
    Dec 2006
    131
    thank you very much :D
