JuicyBackdraft Motorsport
Results 1 to 7 of 7
    Miller's Avatar
    Dec 2005
    S Wales
    13
    Unhappy A4 heater matrix replacement
    Audi A4 Avant, 1.9 tdi, 166k miles
    Wet front and rear passenger foot wells to , hopefully, discover whether or not the heater matrix is faulty I shall disconnect both heater pipes at the bulk head and join together with copper pipe, no water loss then it must be the matrix. I'm not looking forward to removing the fascia to check the matrix!
    Have carried out a forum search but can't find a thread relating directly to replacing a heater matrix so if anyone can post up a link I'd be very grateful.
    The car is consuming approx 1 litre water every 300 miles or so, no sign of leaks other than the foot wells
    Any advice will be very much appreciated
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    13,782
    Its more likely to be blocked scuttle drains TBH mate.
    If the matrix was gone you'd have a sauna effect when you put the heater on...
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Dec 2009
    hereford city
    62
    a dash out job if needed, i did one over two nights about £100 for original audi matrix possible though i used haynes manual handy to find all the fixing's
    Aug 2010
    1,540
    taste the water in the footwells. is it sweet? antifreeze tastes sweet. if it isnt then its not antifreeze/coolant. dont swallow any tho, its poisnous! just dip your finger in it and put it on your tongue. id have a glass of water present to wash your mouth out after.
    Miller's Avatar
    Dec 2005
    S Wales
    13
    Thanks for advice I do hope it's the blocked scuttle drains, but how do you account for the rad water level dropping?.
    Will investigate further and report back
    May 2010
    183
    Just cleaned my scuttle drains out. well took the rubber bits out completely. Hopefully that will stop my driverside footwell getting wet all the time.
    They were clogged up with crap.
    Jul 2007
    London
    2,221
    It could be a corroded radiator. look in the bottom corners for crusty pink deposits if yo're running G12 antifreeze...
    FOR SALE:
