Badger5Chris Nott
Results 1 to 17 of 17
    Jul 2008
    milton keynes
    6
    help with engine running hot a4 1.8t petrol
    Hi
    i have a a4 1.8t 1997 and engine running hot it did have a split pipe which has now been repaired but after filling up it runs at 100 at just running round town when on the motorway goes into 115. tried emptying and starting again but still have the same problem help. also how much coolant should be in it as looks very week now.
    thanks
    ian
    Jul 2008
    Birmingham
    629
    Water pump or thermostat.
    A4 1.8TQS
    Aug 2010
    1,540
    is the heater getting hot?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    Probably the impeller on the water pump has broken.
    Dont keep driving it, or it'll be needing a headgasket next.
    TD5 Land Rover Defender build
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    The pipe probably split due to too much pressure due to the water boiling due to the faulty water pump
    As stated by our resident expert, do not keep driving it without getting it checked
    Aug 2010
    1,540
    if you take the thermostat housing off and thermostst out you can get you finger in to the back of the water pump to see if it feels loose without disturbing all the cambelt.
    colicabcadam
    does your car heat up quicker than usual? if it does, the thermostat is not opening and the water is not flowing through the cooling system.
    if it doesn't, there's a big chance your water pump has gone, do not drive your car anymore, 100 is ok, but 115 is really pushing it and you risk doing perminant damage to your engine
    there is a chance you've not bleed the system correctly, remove the coolant cap, start the engine (from cold) and let it tick over, do any bubbles come up before it reaches boiling point??
    the coolant may also be crap, good coolant does not boil at the same temp as water, more like 110, so if you have crap coolant, it will boil over easier and create airlocks
    jcb
    Sep 2005
    uk
    4,077
    my vote is the pump. get a proper metal impeller one and replace it.
    Is the radiator getting hot? check teh top hose?
    If it is, is your fan coming on? any idle issues?
    check cheap options first, Thermostat (remove drop in a cup of boiling water, if it doesnt open it is goosed), Temp Sensor (swap with a known working one or just replace with new anyway they are cheap).
    Jul 2008
    milton keynes
    6
    heater is getting hot
    jcb
    Sep 2005
    uk
    4,077
    heater matrix is connected directly to the engine not to the radiator and "post" thermostat system IIRC.
    you could have a hot heater but not be up to Tstat temp.
    It is the best way to cool down an already overheating car! whack the heater on full and open the windows!
    Apr 2004
    12,521
    water pump is not driven by the cam belt on these, it's driven by a short V belt.
    It's easier to change with the car in the service position, but probably possible with the front in place but the car in the air for access.
    Aug 2010
    1,540
    Quote Originally Posted by Byzan A4 View Post
    what engine code is it then? aeb?
    Jul 2008
    milton keynes
    6
    hello
    Dont suppose you have pictures do you?
    would you recomend this as a diy job?
    "Stick a V8 in it!"
    15,379
    All B5 A4's use the 058 block which has an external water pump
    the 06x blocks used in B6> A4's and A3/Golfs have an internal timing belt driven pump.
    Apr 2009
    27
    you can do aeb water pumps without moving the front end or lifting the car, its a bit tight but probably the easiest way. getting the alternator bolts back in was the biggest problem i had.
    "Stick a V8 in it!"
    15,379
    sticking the front end into service position will give you that bit extra room, and the only thing you need to remove is the front bumper.
    Jul 2008
    milton keynes
    6
    Thanks everyone new pump in it and works good as gold cheers everyone
