Badger5JMB Retrofits
Results 1 to 23 of 23
Thread: Eibach springs
    Aug 2009
    191
    Eibach springs
    Fitted a set of Eibach springs a while back, the ride height on the back is fine, the front is uneven? The passenger side sits 10mm higher? I thought it would settle but has not!
    Can it only be the springs causing this? I can't think anything else would determine the height!
    I'll have to swop them over side to side and measure them at same time?
    2002 A4 AVANT 2.5 TDI QUATTRO
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    perhaps they're not seated properly in the rubber pad things?
    TD5 Land Rover Defender build
    Aug 2009
    191
    I'll check it all out tomorrow, the passanger side def has more travel than the driver side! Would a blown damper have the same affect?
    "Stick a V8 in it!"
    15,350
    not really, spring holds the car up.
    Aug 2009
    191
    well stripped the suspension, springs are same height etc but spot the difference lol
    would this be the cause of the height difference? the inside of bump stop has disintergrated! Does the suspension sit on the bump stops then?
    audi want about 17 not sure if it includes vat, the other one is solid
    cheers
    Jul 2008
    Birmingham
    629
    Check for dead bodies in the O/S/F wheel well. Sometimes they get stuck up there.
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    Damaged bump stop wouldn't make a difference. They're only there to cushion the blow and protect the internals when the piston becomes full depressed.
    A4 1.8TQS
    Jul 2007
    London
    3,234
    Are the springs the same load rating ? I would check the markings on them as they might be different wich will explain the difference....
    FOR SALE:
    Aug 2009
    191
    Quote Originally Posted by adamss24 View Post
    springs have same numbers, only difference I can find is the bump stop, which is listed in Etka as a 'helper spring'
    will see if it makes any difference tomorrow ta
    Jul 2008
    Birmingham
    629
    Did you cut the bump stops down?
    A4 1.8TQS
    Aug 2009
    191
    Quote Originally Posted by voteforpedro View Post
    nope no need not lowerd car really
    jcb
    Sep 2005
    uk
    4,077
    what do you weigh?!
    Aug 2009
    191
    Quote Originally Posted by jcb View Post
    what do you weigh?!
    cheeky git
    I have now changed bump stop, and the height difference is ****ing worse!
    I'm now going to try changing the complete spring/damper assembly's over and see what happens.
    "Stick a V8 in it!"
    15,350
    have you made sure the spring is against the stop on the rubber pad, and in the lower mounting collar?
    Jul 2007
    London
    3,234
    Thats a good point, the sports bump stops are lower than the SE bump stops hence they will desintegrate quicker. I would make shure you put new sport items IF you have standard suspenssion fitted on the car from factory !
    FOR SALE:
    Aug 2009
    191
    sports suspension is standard on tqs, bump stop replaced has same part number, but instead of being red it was cream coloured for some reason, same length though. Think tqs is 25mm lower as standard and the eibachs are 30mm so only 5mm in it.
    it was against the stop on the upper and lower pads, will have another look friday afternoon, working nights so will have to wait till then lol
    Aug 2009
    191
    well i have tried swapping the damper/spring assemblys over and made no difference so that rules them out. The subframe bushes seem ok.
    Have measured the difference and it's 15mm higher on the passenger side.
    Would the anti-roll bar have and influence on the height? suppose i could unbolt the c links and see what happens?
    Aug 2009
    191
    tried unbolting the c links and that made no difference whatsoever!
    wonder if the top mount plate (that the upper arms bolt to) is damaged. the side that is lower is the side that had the damaged bump stop on so may have taken a hit at some point?
    gonna have to srip it all down again.....meh
    Jan 2004
    York
    1,654
    can you put the original springs on to compare ?
    MY15 8V S3 Sportback with options
    Aug 2009
    191
    ive tried swapping the springs over side to side and passenger side was still lower! also tried swapping the dampers over made no difference.
    last thing I do will be putting the old springs on, could of been same with old springs but just not noticed
    cheers
    "Stick a V8 in it!"
    15,350
    If you've swapped the springs left to right and the same side is still lower, then it cant be the springs...
    Perhaps one side of the car is heavier? Either that or the rubber bushes on one side arent in the right "place" which will be adding to the spring rate slightly?
    Try slackening off the big bushes on the ends of the wishbones, then retighten them with the car on the floor (or jack each side up so its at the correct ride height before tightening)
    Jan 2004
    York
    1,654
    I think there are some procedures you do on the suspension which must be done with the full weight of the car on the ground, otherwise you can get this issue. I'll dig out my erwin pdfs tonight and send them over if you want. Pm me your email addy.
    Aug 2009
    191
    pm sent cheers
