JMB RetrofitsAH Fabrications
Thread: remote CL
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    remote CL
    Righto peeps, my new Acquisition has r/c/l and my current hack doesn't. What would I need to swipe from the donor car to make it work on mine. If it's fairly straight forward I might swap it in.
    Life begins at 140mph
    www.passionford.com
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    if both pumps p/n start 8L0 then swap them over your car will be missing a aerial but its easy enough to add a length of coax that will do the job
    then ideally swap the locks over and if both are immo 1 it should be a case of swapping the boxs over
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Cool, Where's the pump located? I guess somewhere round the back of teh car?
    www.passionford.com
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,349
    Offside rear boot, just behind the light cluster.
    Its encased in foam.
    A '98 will have integrated immo1, so you'll need to swap the speedo heads (assuming the old car also has integrated immo1, you dont say what age it is, but if its new enough to have a 8L0 pump it'll probably have integrated immo1 anyway)
    TD5 Land Rover Defender build
    Milton Keynes UK
    248
    Or just purchase an aftermarket Remote kit from RClick
    You get 2 blank flip keys that you need to have cut. Swap the immob transponder over from the old keys to the new flip keys otherwise it will not start the car.
    URL - http://www.rclick.co.uk/index.php?cPath=50
    takes about 30 Mins to install.
