    TDi Powerrrr
    Aug 2010
    North Devon
    405
    removing silver dash trim
    hi,how do you remove the 2 silver bits of trim off the dashboard?and also the ones on the doorcards?the car is a 2001 b5 facelift.
    thanks
    tony
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,087
    Door cards need to come off, peel back soundproofing and work clips off carefully.
    Dash is a ***** to do, glovebox, drivers knee bolster handbrake and centre console all need to be removed and then it's cack handed to remove the push clips.
    Life begins at 140mph
    www.passionford.com
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Don't try to pry the clips off, you risk snapping the plastic pins they are pushed on to. It's easiest to use an unscrewing action and the same to replace. Mind yer fingers the clips can be sharp!
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Out of interst, what are you doing with the trim? I could do with a couple of bits to replace some dented ones on mine...
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Quote Originally Posted by NineNails View Post
    thanks for the replies.I'm going to be covering them with 3m di noc carbon film,I have done the gearstick surround already.
    tony
