Sky InsuranceVolks Autos
    Jul 2008
    Birmingham
    629
    Glass-like flakes...
    I just turned her over for the first time in 6 weeks and it sounded rough as ****. It also spat a load of shiny glass-like flakes everywhere. The area around the turbo is covered in it. I had the bottom half of the airbox off and had also removed 2 of the 3 turbo > downpipe bolts so there was a small gap there. Must have come from the TIP or this gap.
    Any ideas what they could be?
    A4 1.8TQS
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    Its probably the gasket material from the blowing joint. Theres a shiney coating on the gasket that becomes brittle and dusty with heat/age.
    If you had the TIP off, then the engine was running with no MAF sensor, which explains it running like crap...
    TD5 Land Rover Defender build
    Jul 2008
    Birmingham
    629
    Phew. Just hope none of it got sucked through the TIP. Guess I'll put it all back together and try it again tomorrow. No reason why it would run any differently than it did before the crash tbh.
    Cheers!
    A4 1.8TQS
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Either that, or a Mechaphile has been having a go at your car!!
    Mo power, mo problems
