Volks AutosChris Nott
Results 1 to 16 of 16
Thread: Polybush kit..
    Jul 2010
    20
    Polybush kit..
    Would this still be okay for the FWD 2.4 V6??
    Also would a garage charge a fortune for the changing of these? I am pretty competent mechanicaly but havn't got a lot of tools etc and i should imagine some of the bolts/old bushes will be hard to remove?
    jcb
    Sep 2005
    uk
    4,077
    diy or expect a four figure bill! i paid for mine to be fitted when i had the suspension done.
    would diy in future
    not as tricky as it sounds on most bits
    Jul 2010
    20
    Four figures?? Jeez that bad?? So i should maybe do them bit at a time? Whcih are easy and hard etc?
    jcb
    Sep 2005
    uk
    4,077
    hard ones are pulling the oem ones out of the loer fronts. anything that has a pressed steel case iont aluminium can be a chore. may as well do them all at once TBH, just get a press, penies from machine mart or a load a beer from a garage that has one
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    ive got a set of rear ones to fit
    cant find a press for pennies but this is the cheapest i can find
    would it work?
    http://cgi.ebay.co.uk/12-TONNE-HYDRA...item27b39b7264
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    jcb
    Sep 2005
    uk
    4,077
    bit of overkill at 12tons
    would work though
    TBH if you fit Powerflex they are two peice and can be fitted by hand.
    if you dont mind cutting, drilling, grinding the old ones out it can be done with a few hand/power tools, that way you can swerve the press purchase.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    the biggest problem with the cheap ones like that is it says 12 tonnes but doesnt give you a pressure guage.
    Most bottle jacks have a pressure releif valve which will pop once the jacks pressure has been exceeded, but thats not really the safest thing to be happening is it?
    TD5 Land Rover Defender build
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Quote Originally Posted by jcb View Post
    would work though
    did my old golf using that method and thought never again
    ive got plenty of space for the press and figure id be able to do bearings etc with it in the future
    how much pressure would it need?
    kev
    90 eunos roadster
    "Stick a V8 in it!"
    15,388
    A couple of tonnes unless they're particularly stuck i'd recon, but given the shonkyness of those ebay ones, i'd be going for the biggest you can afford.
    jcb
    Sep 2005
    uk
    4,077
    I did my golf with Prothane which are one peice. if that is what you have a vice will get them in.
    It is getting the steel sheathed OEM ones out that requires the effort, 100 buys a lot of beer.
    I would be getting busy with a drill and a chisel. drill the rubber out and aim the chisel at the outer edge of the sheath to knock the edge in.
    seriously just did this on a full rear suspension (top wishbones L&R, lower wishbones L&R) took me less than 30-40 mins to get the old original ones out. just go easy and dont cut into the arm.
    if you were doing the front I would say get the press. Aluminium arms dont like hammers/drills/grinders!!
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    i live in a pub so dont need beer money
    its the rears im doing
    kev
    90 eunos roadster
    jcb
    Sep 2005
    uk
    4,077
    ha ha, fair enough
    what poly brand are you using?
    only thing I forgot to do when doing them this time was grease them, now sounds like I am running over frogs when I go over speed bumps!
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    i got complete rear powerflex for 60 and front arm shock mounts for 10 on ebay, i think the guy couldnt be bothered fitting them
    dont think i'd of bought them at full cost but couldnt resist for that price
    kev
    90 eunos roadster
    jcb
    Sep 2005
    uk
    4,077
    not bad. I think a front to back kit is over 300 IIRC.
    get some silicon grease or I used some copper grease to stop the squeak
    Jul 2010
    20
    Thanks for all the comments guys,
    Wish i'd done a bit more research before i bought my car because changing all these bushes is gonna cost me a lot of time and money! Gonna tackle the gear linkage first methinks and quickshift it etc.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    they came with little packs of lube but not sure whats in them and they look a bit small
    kev
    90 eunos roadster
