How to keep dipped beam on when using full beam???
Keithsri
NULL
Hi guys, got me some facelift headlights and fitted finally. Good job. But i want to keep the dipped beam on all the time..??.. so when im in dip and switch to full,dip stays on.. instead of going off like it does at the minute..
Anyone know how to do this? isnt there something you do to the light stock???
Thanks Keith.
You need to bridge two pins. There is a write-up with photos on here somewhere.
Ah, i knew it. I had a quick search but gave up, il try again... cheers blue thunder
Our car old car did that without changing anything, but i suspect it depends on what lights the car had originally.
Our car had the triple bulb lights, with integrated fogs. I suspect you had H4 single bulb units without fogs instead.
If your struggling i can look out the wiring diagram.
You must have searched hard for that,i couldnt get it on my second sweep ha, But that the exact thread!! Thanks alot guys,great help!! :D
