Badger5JMB Retrofits
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Water pump drive belt adjustment?
    Hi
    I had some time yesterday so I had a poke about at the engine of my new 1.8t and whilst doing an oil change I noticed that the very small belt from the power steering pump to the water pump is a little slack but I cant for the life of me see any adjustment for it. As it is at the moment it's ok but I can see it wouldn't take much to stop the water pump turning. Is there any adjustment to be had or is it a case of fitting a new belt?
    Also noticed there is no belt fitted to the air-con so that needs investigating as to why....
    On the upside I cured the misfire/hesitation I was getting at 3000rpm. It was a short piece of vac pipe off the intake manifold to a valve thing on the fuel rail.
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Even with a new belt they are far from tight. As long as the pump is turning freely i wouldn't worry as the belt will still turn it without issue
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    As for the AC, its quite likely the compressor has siezed, and the belt has been removed, or burned thru and snapped.
    TD5 Land Rover Defender build
