Badger5Monster Motorsport
    Jul 2010
    6
    selecting gears problem?? can any body help
    Hi there just got a audi s4 b5 99 plate today, it does have some issues usuall things for its age i.e speedo display , a couple of warning signs airbag and brake but need to find out why the gears are a bit vague, when trying to select a gear it takes a couple of a attempts to find it or get it in. does anyone have any experiance with this??? guy did say selector rod had been renewed if this helps. cheers
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    S4 are a bit odd going 1-2 but it can be a shifter alignment problem jhm have a guide how to re-align , its the two hex bolts that hold the shifter rods to the shifter which can be accessed from inside the car . If that doesnt work then its a tranny rebuild.
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
