EM TuningAH Fabrications
Results 1 to 8 of 8
Thread: VagCom Issue
    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Question VagCom Issue
    Hi,
    When trying to run VagCom 409.1 on my netbook I keep getting the error message 'No Response From Controller'.
    This message only occurs when trying to run this on my netbook (XP), if I use my other laptop (Win7)it works fine.
    I would rather use the netbook as the laptop is a huge f-ing thing and only just fits on the seat (17" widescreen)
    Any ideas????
    To date - 2.5" Jetex exhaust, Generic re-map, Silicone hoses, N75k, shiny 17's, FK Springs
    Wanted - Sports cat, bigger downpipe, FMIC, Bigger turbo
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    I would imagine you need to select the correct com port.
    When you attach the USB dongle, windows allocates a com port to it. If you open the device manager you should be able to see which com port its allocated, and ensure it matches the setting in vagcom. Vagcom can only access com 1-4, so if windows has given it a higher number you'll need to change it.
    TD5 Land Rover Defender build
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Checked and tried all comports from 1 to 4. Still no joy
    Looks like I'm going to have to keep lugging the huge laptop until I can figure this out.
    "Stick a V8 in it!"
    15,324
    What com port is the interface using in the device manager?
    Mine sometimes allocates it a stupid port, like Com9 or something, and you need to go into the device settings and change it to a number between 1 and 4.
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    Depending on which USB port I plug it in to it's either 3 or 4 so it's allocating o.k just being a pain in the backside.
    "Stick a V8 in it!"
    15,324
    If its running Vista or 7 then make sure you start vagcom as administrator?
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    As mentioned previously, it is running XP hence my head hurting trying to figure out what's wrong
    gaz71's Avatar
    Jul 2009
    Torbay
    287
    I think I may have worked out what is wrong - after testing the Com Port OK I am clicking on SAVE but I do not think that it is saving the configuration.
    Now all I have to do is figure out how to sort this out
    Any ideas
