Volks AutosJMB Retrofits
    Jul 2006
    gearbox noise on 2.5Tdi V6 1999
    sounds like a bearing, have done gearbox oil change and tried some stuff for "noisey" gearboxes mad sod all difference!
    its a dronen noise even when clutch pushed in and doing 30 mph +
    Any clues? Car has 111k on it and has been well looked after
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Its probably a bearing like you suggest, probably in the diff, but unfortunately theres no easy fix. Its a gearbox stripdown to replace the bearings or a replacement box.
    TD5 Land Rover Defender build
    beachbuggy's Avatar
    Surrey
    1,744
    Are you sure it's the gearbox, the wheel bearing do go on these. Does it get quiter when you go round a corner? ie if you go round a right hand bend, the weight will come off the right side and the noise will soften, obviously vice versa on the left. If it does then it's the bearing.
