Chris NottAH Fabrications
    OldRedEyes's Avatar
    442
    Towbar wiring help needed
    Can anyone tell me what are the wiring colours in the rear lights to wire into my towbar electrics?
    The 7 way relay part is fine, but i can't find the wire colour cods anywhere.
    Thank's in advance
    Paul
    Apr 2009
    89
    Hi - same request as above - towbar was fitted yesterday, now need to 'wire' it up. Came off an 'X' reg B5 Avant with only scotchlocks - no adapters or anything, worked ok for many years. Just need basic advice on which wires (colour codes) to connect to the towbar cable - I'll be soldering them in place.
    Imspter
    Apr 2009
    89
    Hi - job now done, using a wiring diagram from haynes manual and a basic wiring guide online for the trailer socket.
    Although fiddly, job is much easier once the 'braid' is stripped off the wires from the lights to about 8inches back.
