EM TuningSky Insurance
    daz616's Avatar
    May 2010
    swanley kent
    39
    oil light flashing
    just noticed when i start the car the dash flashes with "oil" for about 30 seconds then goes off iv checked the oil and its spot on is this normal !
    Apr 2009
    27
    if its where the trip counter mileage is normally displayed then its just the service light, meaning its due an oil service.
    daz616's Avatar
    May 2010
    swanley kent
    39
    Quote Originally Posted by ado66 View Post
    yeah its on the trip does it have to be reset by audi or is there a trick cheers
    Apr 2009
    27
    depends what year it is. early cars <1998 have to done with vag com or similar. as yours says "OIL" I guess it's the same as mine and can be done using the dash buttons.
    switch off ignition
    press trip reset button and hold it in, turn on ignition still holding it in. should now display "service OIL"
    pull out clock set button keep it held out until "service ---" is displayed
    press trip reset button again. should now display "service INSP"
    reset this the same way by pulling out the clock set button.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,375
    Our old '96 also said "Oil" in the trip counter, and it needed vagcom to reset it.
    The new car comes up in the DIS and counts down, "Service 400miles" etc, not tried to reset that yet though.
    TD5 Land Rover Defender build
