Volks AutosMonster Motorsport
    Mar 2010
    where to buy rear diff mount
    anyone know where i can buy a new rear diff mount or new bush if possible?
    thanks.
    jcb
    Sep 2005
    uk
    4,077
    which one do you need? the rear plate that mounts to the subframe or the "front" rear diff mount?
    TBH I spent a wedge on a bling item on the front rear diff mount, works a charm but over priced, the rear diff mounting plate I tigersealed and it is rock hard now.
    I jack the rear up under the diff now without so much as a movement.
    tube of Sikaflex or tigerseal will do the job for a tenner
    Mar 2010
    its the "front" rear diff mount i need, i already put poly bushes on the one on the back, i can only it in the us (034motor sport)?
    cheers.
    Quote Originally Posted by jcb View Post
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    the 034 one is excellent, although not actually made by them... I fitted one of these (15 mins tops), I used their harder rubber carrier mounts and made a huge difference to the slap..
    replacing the front snub mount was well worth it as well...
    however its now highlighted the older other mounts.
    there is no such thing as bad weather, just the wrong clothes!!
