AH FabricationsChris Nott
Results 1 to 12 of 12
    jcb
    Sep 2005
    uk
    4,077
    rear brake problem driving me nuts!!
    recently replaced some brake lines and in the process of bleeding them I realised they were binding (or to be precise were well and truly bound!).
    finally managed to get a stupid wind back tool online (which is made of chocolate and is fecked already!) but as I ******ed up finding the thread on one piston I managed to pull it out and needed to re-bleed them.
    So pistons wound in, pads and discs refitted, lots of clearance, sliders, pads and calipers all move around no probelm and I re-bleed.
    binding.
    badly!
    what the f@$% is happening here!
    exact same brakes and pads that came off going back on. nothing changed other than a bleed.
    something I am missing here?
    hiltoa's Avatar
    VAG erfahren
    Jul 2006
    on the edge
    299
    Could be an internally damaged flexi hose, letting fluid into the caliper, but stopping it from draining back.
    Nothing feels fast for long...
    2004 Audi Allroad 2.5 TDI L.E.
    Ebony Black.
    1991 VW Golf GTI 16v
    Tornado rot.
    jcb
    Sep 2005
    uk
    4,077
    no flexi hoses on my car!
    all new stainless braided, dont see any damaged ones, but I supposed there could be a crimp, but surely it would leak away after some time?
    May 2010
    194
    Still a sticking piston or slider pins I'd say.
    What about the handbrake and it's mechanism?
    jcb
    Sep 2005
    uk
    4,077
    sliders are not sticking, easily pull out with finger and thumb.
    Handbrake is tight but the spring is fully open som it is not on.
    before I bled it the caliper could be slid back and forth in the gap that the piston rewind had created, hand brake hasn't been applied since then so I ruled that out.
    when I was bleeding them I had to get the pedal man to pump a lot of air out since I had opened the piston up, once it came through without air the pedal firmed right up.
    I closed off the nipple with the pedal down to avoid air being sucked back in as I alwasy have done, just this time it doesn't release for some reason. bled them with the ignition off the first time and with it running the next time.
    no idea what it can be
    May 2010
    194
    curious...
    I always lock off the bleed nipple with pedal down, how it should be done.
    No need to have engine running though.
    Have you bled the rest of the system recently? I'd do that anyway as a matter of course.
    But if only one caliper sticking then the problem must lie in the pipe to that caliper or the caliper itself. It's possible it's further up in the ABS unit/controller, master cylinder but very unlikely.
    jcb
    Sep 2005
    uk
    4,077
    I am going to strip it all down again tomorrow but it is really pissing me off now, can has been off the road nearly over a month with various cock ups tools missing or parts on order!!
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Does seem like a strange one.
    Jul 2007
    London
    3,252
    JCB, did you bleed before you pulled the handbrake or after ? There might be dammage to the worm screw but i would rewind them fully then push the brake then adjust the handbrake.
    FOR SALE:
    jcb
    Sep 2005
    uk
    4,077
    havent had a chance to touch the handbrake, just reconnected it
    jcb
    Sep 2005
    uk
    4,077
    sorted it!
    stupid thing really, there is a slight casting difference between the rear uprights from the 1.8tqs ones to the ones I bought from Docurley, that meant the rear lower "leg" that the rear tie rod bolts too is slightly fatter with a defined casting ridge that fouled the 90 deg bend of my goodridge motorsport braided brake hoses.
    as soon as you put the brakes on it held them in place.
    quick squiz with a tungsten carbide bit and it cleared the casting right up.
    Back on the road.....finally, only been 6 weeks!!
    cheers for the suggestions anyway
    May 2010
    194
    Wow, you shoudl patent that design.
    Self-holding rear brake. For those unsure if they want to release the handbrake.
    Glad you got it sorted .
