JMB RetrofitsChris Nott
Results 1 to 8 of 8
    A4 Quattro Sport's Avatar
    Top Gear
    Sep 2006
    Scotland
    36
    Help! A4 1.8TQS Cut out and wont Start
    My 1.8TQS cut out an now wont start. Just before it cut out it was really down on power and struggling to climb a hill.
    I have checked the cam timing and its fine, the fuel pump is working, it is getting a spark but still wont fire.
    I have plugged in my freeware VAG-COM and it doesn't find any fault codes under the engine module.
    Control Module Part Number: 8D0 907 558 DA
    Component and/or Version: 1.8L R4/5VT MOTR HS D01
    Software Coding: 04201
    Work Shop Code: WSC 06325
    No Faults Found
    or DTCs not supported by controller
    a communication error ocurred
    Any help, would be much appreciated!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    Try unplugging the MAF sensor?
    You may need to remove and dry off or replace the plugs, as they might be soaked with fuel.
    Is it actually injecting petrol?
    TD5 Land Rover Defender build
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    my money is on the lower pulley key sheared, but could just as easily be fuel pump or relay related
    jcb
    Sep 2005
    uk
    4,077
    ditto, check you timing (front pulley to cover notch and cam gear to cylinder head.
    I bet it is not firing because it has zero compression due to the bent exhaust valves.
    either crank pulley or stripped belt jump a few teeth
    "Stick a V8 in it!"
    15,317
    If it had mashed its valves you'd hear it when cranking surely?
    Engines with no compression sound totally different to normal ones, you dont get the characteristic "wub wub wub wub" noise when cranking.
    Top Gear
    Sep 2006
    Scotland
    36
    Thanks guys. I'll check the timing tonight.
    The cambelt tensioner failed a few month ago and i had to rebuild top end replacing all the exhaust valves. Belt looks ok, but sheared pulley key could be the answer, the pulley may have gradually crept round so far that the timing is out.
    Hopefully no bent valves. :-(
    Jul 2007
    London
    3,211
    If there is no start there are many bent valves...
    FOR SALE:
    Top Gear
    Sep 2006
    Scotland
    36
    it was a sheared pulley key. All sorted and started no problem.
