EM TuningVolks Autos
    Apr 2010
    vac-com needle lift sensor????
    hi there ive plugged my car into vac com its saying open/closed curcuit, needle lift sensor.
    my car drops off boost at 2800rpm and re-spools at 3100rpm (where all the touque is) its very anoying when trying to over take and the power drops off, it starts to happen after 10-15mins of hard driving, could this be down to the needle lift sensor fault??? how do i fix it
    all the best
    danny
    simon.m's Avatar
    Oct 2009
    2,746
    hi danny have i can help with the problem apart from say have a look here with the code your vag.com give you as it offers what to do`s
    hope this helps
    http://wiki.ross-tech.com/wiki/index.php/Main_Page
    simon
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The needle lift sensor is mounted on one of the injectors, I think it helps regulate fuel flow in relation to pump pressure, so it's most likely responsible for your poor running. Its either the valve knackered (it's quite expensive) or possibly a short in the wiring to it somewhere.
