I've had a few sets of various spacers, as long as they are hubcentric, it shouldn't matter, fk were fine, h and r are better quality, 10mm - you'll need long bolts I got them from pri racing or you can get them off ebay around £1.50 each.
Hi
thanks for the reply did you fit them to the rear of the A4 as theres a slight depth issue with the size of the hub on the back where the spiggot sits thats why i was wondering
its a buy once issue
many thanks
Paul
The only issue I had is that the flange protruding from the middle of the spacer is a slightly different profile shape to the original hub profile which caused the spiggot rings in my wheels to not sit flush against the spacer. The result was that the spiggot ring cracked when the wheel bolts were tightened up. To get round this I got another set of spiggot rings and got a mate with a lathe to just remove a bit of material from them so they sit flush against the spacer, hopefully stopping these ones cracking too.
