EM TuningBadger5
    Danb's Avatar
    Simples
    Feb 2009
    West Brom
    63
    I'm struggling to bleed the coolant system - 1.8T BEX
    Hi Everybody,
    I have fitted a new thermo today and I can't seem to get the air out of the systrem.
    I know about the metal pipe accross the inlet manifold which has a bleed screw, and I also called the Audi main dealer to pick his brains. He also mentioned the pipe across the inlet and also the loosen the pipes that go into the heater matrix at the bulkhead. He also mentioned how they find it hard themselves.
    I need help guys.
    Thanks in advance
    2003 Audi A4 Avant Quattro Sport 1.8T (190) 6 Speed
    Dolphin Grey - Factory HID's - Full Colour Dis - DX Sat Nav - GmbH Bodystyling - 18" RS4 Wheels - BOSE Symphony - Black Grill Surrounds
    Planned Enhancements:- 19" BBS LMs - Eibach Springs - Koni Sports - B7 RS4 Rear ARB - A FRONT TOWING EYE COVER!
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Undo the little plastic screw and open the expansion tank cap and worm up the engine. Once up to temp open bleed screw and using your hand pump rad hose connected to the metal pipe. Do not take the screw out just undo the screw so the coolant can weep out. The plastc screw's are prone breaking.
    AUDI A4 190T S-LINE.
    Danb's Avatar
    Simples
    Feb 2009
    West Brom
    63
    Thanks for the advice CMD. Though I had to call the Audi dealer's service dept.
    He told me to find the heater matrix pipes that are behind the scuttle panel. You have to take off the clip and pull the pipe off until the little bleed hold is exposed. You have to do what you said CMD said then hey presto........or it would be but my water pump is done for. This is a time consuming job, though my good friend who worked for VW for 25 years tells me that the dealers have a adapter that they screw into the expansion tank. This makes the expansion tank the highest point in the system and therefore gravity will do its thing. He says they just fill up the adapter with water and leave it for 30 mins. Simple with the right tools eh!
    coyote's Avatar
    Dec 2007
    213
    Also unscrew the expansion tank and raise it up so that the bleed screw is much lower than the tank
    As said get the car upto temperature and squeeze the pipes.
