JMB RetrofitsChris Nott
    Re: engine warming routine
    Sounds similar to me, then give it a pasting roads permitting!
    I seem to stall mine a little too, as normally change up too early and as it pulls from low rpm tend to leave it in high gears.
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Glovebox 6 cd changer
    Part No: 8E0 035 111
    Does anyone know whether this is the one that goes with the concert 2 head unit in the b6 a4?
    Also, will I need a new glovebox, or will this just fit into the current one?
    I was the second highest bidder on ebay, but looks like the winner was a time-waster so the seller has offered it to me. Is 130 too much?
    Mar 2004
    Manchester
    1,306
    Re: Glovebox 6 cd changer
    Though I'd stump you all with this one!
    scoTTy's Avatar
    Essex, UK
    1,958
    I can't help with the part number but this looks the same as in mine. I believe it's the same glove box inner. Try your dealer for more info. They can look it up for you. :
    Vagparts.com
    Mar 2004
    Manchester
    1,306
    Thanks ScoTTy, the unit does look the same from the front. Do you know what the rear connector looks like? This is what it looks like on the unit I want to buy.
