JMB RetrofitsBadger5
Thread: Tyres
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Question Tyres
    What difference would fitting 245 40 17 do to a car on the rears when i normally fit 235 45 17 as an all rounder?
    when i line the tyres up they look almost the same,
    paulsb's Avatar
    May 2010
    lanarkshire, Scotland,
    138
    not much, there only an inch wider. what are your alloy? 17x8?
    66
    Isn't this a problem with quattro cars?
    '04 A4 Avant 1.8T Quattro LE - Retrofitted: RNS-E, Bluetooth, front centre ambient lights, full DIS, cruise control, alcantara steering wheel, more to follow....
    Gone but not forgotten - '98 A3 1.6 SE, '01 S3, '01 A4 1.8T Quattro SE, '02 TTC 225, '04 A3 3.2 Quattro S-Line DSG
    Turkster's Avatar
    Dec 2007
    2,723
    i have 17" alloys and yes its a Quattro
    paulsb's Avatar
    May 2010
    138
    if you stick 245/40/17 on and you have 17"x8" alloys, the 245 will make the tyre over hang on the front of your alloy by about 1 cm.
    if you plan on doing this i would suguest you put 245/45/17 on the rear otherwise your rear tyres will have a shorter circumference and would mean your rear tyres spin faster than your front tyres which could cause problems with your esp.
    i don't personally know if this messes up the quattro or not. if i had to guess, i don't think you would have a problem with the tyre size i sugested.
    good luck either way.
