Chris NottSky Insurance
Results 1 to 14 of 14
    39
    1.9 tdi - poor mpg
    Hey there, my tdi 130 (AVF) has had a few running issues of late so I changed the MAF meter and the problems are long gone, however the mpg seems to have dropped drasticly, struggling to reach 32mpg of late and often a quick trip to the shops will only see 25mpg or so! Likewise I just brimmed the tank and it only said 460 miles left, not the usual 600 or so.
    Anyone have any ideas, is there an ECU reset or similar that can be done?
    Any help gratefully appreciated
    Thanks Glen.
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    ecu can be reset by disconnecting the battery for 10 minutes.
    don't know if that will help much but worth a try
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
    39
    Thanks for the reply, tried this yesterday, took it for a run and the mpg readout still seemed low, then the engine warning light came on! One step forward and two back.
    Will try and use a fault code reader today? Anyone else had similar issues or know of any? Any Vag tech's on here?
    Cheers Glen.
    paulsb's Avatar
    May 2010
    lanarkshire, Scotland,
    138
    don't know if this applys to diesels aswell but i had a 325 with the same problem. as far as i know there are 3 things that control the amount fuel you use, ecu, maf and the lambda sensor. with the 325, it was a new lambda sensor that fixed the mpg.
    hope this is useful
    39
    Thanks for the heads up Paul.
    Got the codes read and got the info as follows: -
    Code 1
    P0234 - limit exceeded (overboost)
    calculated load - 100%
    coolant temp - 87C
    Intake map - 252kpa
    3572rpm
    Intake air temp - 49C
    MAF - 156.16 g/s
    Throttle position - 98.82%
    Code 2
    coolant temp - 87C
    Intake map - 252kpa
    4119rpm
    Intake air temp - 54C
    MAF - 161.27 g/s
    Throttle position - 83.13%
    If anyone could offer any further advice it would be greatly appreciated as this is doing my nut in and spoiling the ownership of a cracking car.
    chrisash32's Avatar
    Manchester
    575
    Quote Originally Posted by subtle View Post
    Its a long shot... but lift off the gas a bit? 99%!! lol
    paulsb's Avatar
    May 2010
    138
    Code 1
    coolant temp - 87C
    Intake map - 252kpa
    3572rpm
    MAF - 156.16 g/s
    Code 2
    coolant temp - 87C
    Intake map - 252kpa
    4119rpm
    MAF - 161.27 g/s
    found this site explaining fault codeshttp://www.bentleypublishers.com/tec....dtc.table.htm
    best guess is the boost on the turbo is too high.
    has your car had a remap?
    simon.m's Avatar
    Oct 2009
    2,746
    if your using vag.com for the fault codes look here mate...... http://wiki.ross-tech.com/wiki/index.php/Main_Page
    39
    Quote Originally Posted by chrisash32 View Post
    Haha I wish!
    Paul/Simon I just borrowed a mates mac tools code reader, no remap I'm afraid.
    paulsb's Avatar
    May 2010
    138
    best guess would be that the boost from the turbo is too high. that would explain why you mpg is lower than it should be.
    can't say for sure as it's usally petrols i play with.
    good luck
    39
    After some digging around last night I found a loose breather hose located just in front of the radiators which appears to go to a 1-way valve, reattached it, went for a spin and hey presto got 46mpg after some spirited driving and a more responsive and smoother car. So I'm a happy bunny for now lol.
    Hope this may be of some help to anyone who is suffering similar problems or the 'sticky turbo vanes' symptom.
    Glen.
    iyrix's Avatar
    Mar 2010
    427
    Glen.
    Thats good! Glad you have got it sorted. I take it your just going by the DIS? Do you work your MPG out when you fill up?
    G.
    Audi A4 TDi 130 Sport
    39
    Just used the DIS so far as we have only owned the car 3 months or so and this problem has occured for 2 months of those, but now everything is running ok I will work it all out, I'm sure there's an app for that lol.
    iyrix's Avatar
    Mar 2010
    427
    Thats right, there is....
