Right, need some advice please guys.
Few days ago I got d car diagnosed and had 2 injector faults. Straight after that the car wouldn't start. Jumped it and it was fine. Next day it took 3 attempts to start up, following day it wouldn't start at all. Just got the AA to have a look at it, they couldn't start her up.
Coolant was empty and had a tiny bit of brown gooey stuff on the oil cap, he said some oils can produce that or it's a blown head gasket.
He said it could also be that the injectors are flooded with fuel, so it won't start, or the coolant has gone in the cylinders ( think that's what he said) which blew the head gasket.
What's the likelyhood of each if d above?
My car is serviced regularly, and apart from misfiring there's no problems with it.
Just to add, I had timing belt, thermostat and water pump changed 2 weeks ago.
D AA geezer said it's also a possibility that when the timing belt was changed, when d mechanic topped up water, he didn't let all d air/pressure out and as result, blew the head gasket. But my car hasn't overheated, temp needle is bang on at 90degrees.
Please help, car is now stuck on the drive, won't start and my mechanic won't be able to take a look till sun/next week.
