Thread: brake warning
    Apr 2010
    346
    brake warning
    when i start my car a symbol with brake flashes on the dash and beeps 3 times.
    there is a brake bulb gone could it be that.
    thought it might be fluid level but thats fine,i know i could just change the bulb and see if that sorts it but that would be to easy lol.
    Aug 2009
    833
    abs sensor normally. get vag com on their and find out fo sho. if you are anywhere near reading i could give it a quick scan.
    Apr 2010
    346
    thanks for the offer mate but i live in ireland,i got a scan and there is nothing showing up bar a needle sensor in the injector pump.i put in a new bulb today and it doesn't work.thought it might be the switch on the pedal but would that mean that all the break lights wouldnt work
    Apr 2010
    346
    bump
    oopee's Avatar
    Oulu, FINLAND
    17
    LEDs can induce brake alerts too...
    A4 B6 Avant 1.9TDI AVF quattro by turbotec
    Jul 2007
    770
    Most likely the sensor under the brake fluid res is being triggered by an electrical spike.I fixed mine by moving the wire from the battery which was touching the sensor and charging up the battery others have gone for a new battery which seems to cure it
