Volks AutosBadger5
Results 1 to 10 of 10
    190 S LINE QUATTRO
    somerset
    81
    Wheel spacers on my 1.8T quattro s-line 190.
    Hi there, my 1.8T quattro s-line is totally standard, it's got the 18" ronal 5 spokes, was just wandering about wheel spacers to bring the wheels out a bit, don't want it looking chavvy just a bit of a meaner wider stance. Not sure if just the rears or front and rear, what thickness spacers, if same on front and back, will longer bolts be needed and where to get them from and price, anyone got any pictures, will the handling be affected or wheel bearings wearing prematurely. Sorry for all the questions but don't want to make it look ****e.
    matttrs's Avatar
    Mar 2010
    164
    if you're going to get spacers you want to measure the gap from the edge of the wheel not tyre to the edge of the arch and get them around that measurement. you want the bolt on ones that you bolt your wheel to ideally, as thats a lot more secure, rather than the bolt through long bolt ones. look at h+r and Fk ones. lots of others too. I've run adapters for the last few years and not affected the bearings.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Quote Originally Posted by matttrs View Post
    Not sure I would agree with you here matt - bolt-through spacers are just as secure as long as you get good quality bolts. Some people on here have been racing with this set-up for years and not had issues.
    If anything, the spacers with bolts on them are less secure as you are relying on the point where the spacer is attached to the bolt, which is a major weakness point in the whole set-up. As majority of these types of spacers are made of aluminum, the softness of this metal could prove to exaggerate the issue.
    just my 2 pence
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,290
    A popular choice is 15mm rear and 10mm front. As mentioned, if you stick with good quality spacers and bolts you'll be fine.
    http://www.dpmperformance.co.uk/whee...f75ed89a5db8bb
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    matttrs's Avatar
    Mar 2010
    164
    fair enough, either type then. didn't realise that.
    May 2009
    214
    Spacer are sound for what ever you want to use the car for as long as you get longer bolts with the standard shaft length and width of the spacer added!!
    Im using 5mm spacer on the front ET37 and 8mm on the rear ET34
    Think you also need hubcentric spacers if you go above 10mm
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    15mm Wheel spacer's on 19x9" wheel. No problem wheel has a 44 offset.
    AUDI A4 190T S-LINE.
    Apr 2010
    Burnley, near monty carlo !!!
    351
    I've been making my own spacers for years im a cnc programmer by trade so easy enough to make if your going above 10 mm you'll need hub centric spacers as the wheel will need to sit on a diameter so as to avoid been un balanced.
    I've used 20mm spacers in the past without been hub centric but i wouldn't recommend it. Im currently running 8mm on the rear with 45mm of thread bolts, there to long really for the spacer thickness as im getting 17 full turns with the brace, there really meant for something around 15mm thick which would give you about 8/9 full turns with the brace which is fine if a bit much.
    As a rule of thumb going off my experience 5/6 full turns with the wheel brace which = about 7/8mm of thread for the rear is fine + 6/7 turns for the front which = about 9/10 mm of thread.....Bit long winded answer i know but i've spent years making and fitting god knows how many different sizes.
    I always use alloy either HE15 or HE30 stay clear of steel to heavy.....
    A4 TDI SPORT with full leather and thats it as standard.Fitted by me.Remap,S-LINE BADGES.S4 Wing mirrors.DIS,Seat Cupra splitter.Rear parking sensors.5k hids+LED side lights+DRL lights+chrome indicator bulbs,amber fog lights.LED Xenon number plate bulbs,upper/lower front grills+boot strip in matt black.Ipod dock.19" BMW X5 SPORT CONCAVE ALLOYS,9 J FRONT 10 J REAR 20mm hub adapters front ET 28,18mm hub adapters rear ET 27.
    TO DO.B5 spring perches.Renault rear diffuser?? S/S exhaust.
    matttrs's Avatar
    Mar 2010
    164
    just to kinda threadjack, what width offset and spacer would give a flush to the arch look?
    i have 18x9.5 et 47 wheels not sure what width adaptors to buy.
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    15mm rear's 10mm front's..
