Hi,
I had a scan done today thanks to Dave from B8 forum.
It shows 2 errors which I want to fix asap.
FIRST ONE
17664/P1256 - Engine Coolant Temperature Circuit (G62): Open / Short to B+
Possible Symptoms
Difficulties with starting a cold engine.
Diesel: an indication is extreme long time burning time of the glow indication light.
Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
RPM at idle is irregular.
With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
Bad acceleration during warming up.
Possible Causes
Wiring and/or connections faulty
Engine Coolant Temperature Sensor (G62) faulty
Possible Solutions
Check wiring and connections
Check / Replace Engine Coolant Temperature Sensor (G62)
Special Notes
In MY 1995-2002 (?) in Europe at VW-cars the G2/G62 had the bad reputation of breaking down often. The default G2/G62 is black and all replacements are green.
SECOND ONE
17994/P1586/005510 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
Possible Causes
Wiring/Connectors from/to Engine Mount Solenoid Valves (N144/N145) faulty
Possible Solutions
Check/Repair Wiring/Connectors from/to Engine Mount Solenoid Valves (N144/N145)
Check/Repair Engine Mount Solenoid Valves (N144/N145)
Category: Fault Codes
Any idea if its easy to change coolant sensor? Would prefer to do it myself when I have a spare minute.
Maybe price from stealers ?
With the engine mount solenoid valve am I looking at new engine mount?
FIRST ONE
Possible Symptoms
Possible Causes
Possible Solutions
Special Notes
SECOND ONE
Possible Causes
Possible Solutions
