vrbob
Hi Guys,
Had a few issues in the last week or so so i have been doing a few scans here and there with my VAG-com cable. I posted in another thread that the emissions control light came up on my dashboard on the way home so i did a scan which said my engine coolant temp sensor was faulty so i have replaced that but i am still getting a needle lift sensor error plus a few others to do with my RNSE so i thought i would post up the faults for one of you more experienced members to tell me what might be wrong.
Here is the list of faults :
VCDS Version: Release 908.2
Data version: 20100326
Saturday,15,May,2010,15:43:28:10420
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8EX4A216615 Mileage: 164160km/102004miles
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 8E0 907 401 J
Component: 2.5l V6 TDI G000AG 0006
Coding: 02006
Shop #: WSC 63251
Part No: 00006059
Component: 130 106LC150_1.V79088384482
WAUZZZ8EX4A216615 AUZ6Z0D0005696
1 Fault Found:
00542 - Needle lift Sensor (G80)
30-10 - Open or Short to Plus - Intermittent
Readiness: 0 0 X X 1
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 D HW: 8E0 035 192 D
Component: RNS-E HIGH EU H70 0650
Revision: 01S Serial number: AUZBZ7E1112689
Coding: 0301717
Shop #: WSC 06348 116 65470
4 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:33
Freeze Frame:
Mileage: 655350 km
Count: 1505
Clock: 15:32
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:33:13
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:28
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:33
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301717
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:33
Freeze Frame:
Mileage: 655350 km
Count: 1505
Clock: 15:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:33:13
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:28
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:33
I have done a quick serch via google on the needle lift sensor and i think i have found the wire coming out of the left bank of injectors so i traced the wire to the connector which i have removed and given a good clean but this has not rectified the issue. The car seems to drive fine and still has lots of power and no flat spots so i am not sure how the needle lift sensor being faulty may affect the car. I am guessing if it is knackered it aint gonna be a cheap easy fix
As for the RNSE faults it looks like the RNSE (i retrofitted) still thinks its in the previous car as the mileage etc is wrong so i am gueesing i just need to reset it all but how do i do that exactly?
Cheers in advance
69 75 76 77
Coding: 02006
Shop #: WSC 63251
Part No: 00006059
1 Fault Found:
Coding: 0301717
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:33
Freeze Frame:
Mileage: 655350 km
Count: 1505
Clock: 15:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:33:13
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:28
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:33
Coding: 0301717
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:33
Freeze Frame:
Mileage: 655350 km
Count: 1505
Clock: 15:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:33:13
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:28
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2010.05.15
Time: 15:32:33
Cheers in advance
