Volks AutosMonster Motorsport
    LIVERPOOL
    Jul 2009
    LIVERPOOL
    39
    Boot won't open?
    Hi all,
    Well I can open the boot using the key, but when I press the button on the key it just makes the sound but doesn't unlock.
    I don't know if I will need a whole new lock, or if it's just one part like the microswitch or something.
    Has anyone had the same problem and how did you fix it?
    I have attached a video it might help? as you can see it starts off with loads of power then dies off.
    Dec 2009
    76
    Looks like the actuator motor is knackered , common fault about 35.
    chrisash32's Avatar
    Manchester
    575
    yep, mine went like this, replaced the motor, works perfect now
    LIVERPOOL
    Jul 2009
    LIVERPOOL
    39
    Thanks for the replies guys, i'll get it sorted.
