Sky InsuranceAH Fabrications
Results 1 to 14 of 14
Thread: retro cruise
    Aug 2009
    cork
    117
    retro cruise
    hey, anyone know what i need to retrofit cruise. how difficult is it to do
    A4 1.8t 190 sport http://www.rpselectrical.ie
    Niknak's Avatar
    Oct 2006
    manchester
    864
    I had mine done by VWCruise, didn't seem that difficult while I watched them, vag.com and a new stalk + cowling was about it tbh.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    you will need to know what module you have to see if its compatible with cruise.
    vagcom will tell you this.
    if you have the correct one then as niknak says, cruise stalk, no need for new cowl, your cowl can easily me trimmed to suit. and code the car to tell it it has cruise.
    i wouldnt !!!! recommend vwcruise, way way to greedy.
    have a go yourself , if not get some off here to do it for you , will work out alot cheaper
    LOTS DONE, LOTS SPENT !!!!
    Niknak's Avatar
    Oct 2006
    manchester
    864
    I agree they are expensive but it is horses for courses if your handy go for it, if not then get an expert to do it....
    Aug 2009
    cork
    117
    cool is the stalk an ad on to the one i have or is it a whole new stalk, when i check with vag com how will i know if the module is compatible + what do i go into to check, thanks for the info
    Niknak's Avatar
    Oct 2006
    manchester
    864
    The stork is a new addition to the steering column
    66
    Before you plan which Sunday afternoon you'll do all this on, check the 2 things that tripped me up - the torx driver to remove the bottom cowling needs to be LONG!! I had to trim the plastic off the handle of the halfrauds one I bought. Also, on your dummy run to test your torx driver, check the marking for where you need to cut the plastic on the inside of the cowl to allow the stalk to protrude, this wasn't there on mine, had to buy new pre-cut cowl from the stealer.
    '04 A4 Avant 1.8T Quattro LE - Retrofitted: RNS-E, Bluetooth, front centre ambient lights, full DIS, cruise control, alcantara steering wheel, more to follow....
    Gone but not forgotten - '98 A3 1.6 SE, '01 S3, '01 A4 1.8T Quattro SE, '02 TTC 225, '04 A3 3.2 Quattro S-Line DSG
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    mines booked in on monday at awesome GTI, cant be arsed with the hassel of doing it myself
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    whats that costing you scott
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Awesome do a deal on E-bay 249.00, so should be costing you around that.
    scott b's Avatar
    1,254
    as above 249, plus there only less than 10 minutes down the road from mine
    Lancaster
    1,788
    Everything you need for the job and full dis is forsale through me if you're interested?
    To do: None yet.
    Aug 2009
    cork
    117
    just checked steering module its ending in F, anyone know whether its suitable
    Lancaster
    1,788
    No, That won't support cruise control iirc.
    There are 3 types of steering column control modules, only 2 of them support cruise control.
    • Lowline
      • Supported Steering Wheels: Standard Steering Wheel (4-Spoke)
      • Supported Features: Trip Computer (does NOT support Cruise Control!)
      • Part Numbers: 8E0-953-549-F 8E0-953-549-S
    • Midline
      • Supported Steering Wheels: Standard Steering Wheel (4-Spoke), Sport Steering Wheel (3-Spoke), Multi-Function Steering Wheel
      • Supported Features: Trip Computer, Cruise Control
      • Part Numbers: 8E0-953-549-L, 8E0-953-549-N
    • Highline
      • Supported Features: Trip Computer, Cruise Control, Steering Wheel Heating
      • Part Numbers: 8E0-953-549-M, 8E0-953-549-P, 8E0-953-549-Q, 8E0-953-549-R
    To do: None yet.
