Volks AutosBadger5
Page 3 of 3 FirstFirst 123
Results 81 to 111 of 111
Like Tree2Likes
Thread: Reverse Camera
  1. #81
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Quote Originally Posted by Pabs View Post
    Great write up very helpful, just a quick question about the reverse camera number plate light, i have led number plate lights which are xenon white, what colour is the reverse camera number plate light?? If any one has a pic at night could they post it.. Thanks
    It is an LED type light but not very intense white - actually closer in colour to the original number plate lights but marginally whiter.
    You can't change the camera number plate light as it's a sealed unit and the LED's are soldered onto a circuit board.
    Also note that the light is about half the size of the original and the camera does shed a shadow on part of the number plate - you can see the the diiference in light colours in the daylight pictures above.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
  3. #82
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    Thanks for that woorlord, might have to look at the reverse camera that fits in a parking sensor hole now, i like my led number plate lights. Cheers
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, Coilovers
  4. #83
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    I have seen this Audi A6 number plate camera which maintains the full light which looks like it takes a standard bulb - or your own LED solution.
    Downside is the expense - 102 for the unit!
    The other problem is comaptibility - looks like the OEM lights are different from A4 to A6. I think the later "new" A6/2005 may be compatible with later A4's - i.e. A4 "8E-3-385 001 >>" are same as A6 "4F-5-000 001 >>".
    Mike.M likes this.
  5. #84
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    Thanks for the info, i was thinking of something like this:
    LED Night Vision Car Rear View Backup Reverse Camera on eBay (end time 14-Feb-11 07:09:34 GMT)
    Woorlord where did you buy the multimedia adaptor from or did you make your own??
  6. #85
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    i meant interface not adaptor
  7. #86
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    A bumper mounted camera is going to spoil those nice lines at the back and give you a straight out view - more like a rear view mirror view. The number plate light camera's point down giving a better view to assist you in parking. Nuimber plate light cameras are nice and discreet - see from the pictures previously posted.
    Multimedia interfaces, (as already mentioned in thread #27) are readily available from Ebay or Kufatec. Mine is from Poland off Ebay like this one. I made my own "Auto Video switch box" as documented above.
  8. #87
    Dec 2011
    Need help!
    I installed my camera - which looks identical to the one in pictures.
    Basicly there is a loom that is going into tail light. I cut the red/blue wire and spliced it with red wire that came pre cut from the power connector. then I cut the brown thicker wire and spliced it with black from from cam power cable connector.
    I connected the video to Navi - but its not turning on.
    Also - I noticed that led is very dimly on when key is turned to II and it doesn't matter if I'm in reverse or even if cable is attached to red cam cable, led stays on with Key II but it is pretty dimly lit.
    Then when I turn on the lights - license plate light lights up and cam Led lights up very brightly.
    Can anyone help? It's a b7 US. Also I suspect my navi is PAL and cam in NTSC..
    Happy Holidays! Please advice if any clues?
  9. #88
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    Quote Originally Posted by null View Post
    Test the connections and camera......
    1. Test the power feed to the camera - use a DVM (Digital Volt meter) - should read 12v when reverse selected.
    2. Hook up the camera to a monitor (TV with AV input) - could use a very long video cable to do this. Do you get a picture when reverse selected? (Alternatively take camera out of car and test in house with TV AV input to check camera working 100%)
    3. PAL/NTSC is handled by your Audio/Video Multimedia interface between your camera and RNS-E, nothing to do with the RNS-E. The RNS-E simply takes a component RGB signal. Your Home TV may be able to confirm the signal source type if it can handle NTSC/PAL etc. and displays the decoded video signal. My Pioneer plasma is multi standard and shows this when the signal is first selected or fed to the panel.
  10. #89
    A4 TC's Avatar
    1.8T quattro sline
    Nov 2006
    Toon Toon
    199
    I've had this done to my motor ! But I don't have RNSE ! instead I've gone for the TFT rear view mirror !
    Worked out at about £80 for parts and labour !
  11. #90
    Aug 2012
    Melbourne, Australia
    12
    I have just ordered the bits and pieces to do this myself to my B7. I have an RNS-E from the factory (had the car since new) with bluetooth, nav, 6-stacker in the glovebox, but no ipod or TV.
    I have coming;
    1) a multimedia interface
    2) iphone/ipad video/audio/usb adapter cable
    3) iphone dock extension cable
    4) will order the camera, about to confirm correct size
    Woorlord, I plan to implement your auto-switcher for reverse camera (nice work btw). from your wiring diagram it looks like you are using the 12v from reverse (lights?) to switch the relay, that is all good, but are you jumping that same 12v feed into the RNS-E to have it auto-display the camera ("TV"), because this is not shown on the diagram. If you are, which connector on the RNS-E is this, and is it labelled? (I've not had my RNS-E out of the car yet)
    cheers
    Ben
  12. #91
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    My Reverse camera is fed off the reverse light power feed in the boot.
    With regards to a Reverse Signal for the RNS-E, this I already had at the front near the Engine ECU/Tiptronic Gearbox ECU as this fed the Auto-Dimming Rear View Mirror - so just extended this from the right a-pillar to the back of the RNS-E into the RVSL (C2) pin.
  13. #92
    Aug 2012
    12
    So is the reverse signal that needs to feed to the RNS-E the output from the gearbox, and is this something different to the 12v from the reverse lights? I understnad in your case you had the mirror setup so you used that, I'm just trying to understand if there is a difference between the 12v that feeds to reverse lights and the reverse signal from the gearbox?
    I have the auto-dimming mirror also (factory)
  14. #93
    27,121
    Afaik you dont need reverse wire to switch to the tv input, there's a coding you can enable to do this on the rns-e:
    A004,0,Rear View CameraA
    004,5,Rear View Camera
    A004,6,0 = Rear View Camera not installed
    A004,7,1 = Rear View Camera (Lamborghini) installed
    A004,8,2 = Rear View Camera (DDP/RNS-E HIGH) installed
    A004,9,3 = Rear View Camera (BAP/RNS-E PU) installed
  15. #94
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    Quote Originally Posted by Modena View Post
    The RVSL signal is a switched 12 Volt signal, so same as that which goes to the reversing light bulbs.
    You have a B7 so the Auto Dimming Mirror does not use the reverse signal fed to it - you have a manual switch to turn dimming function on/off but additionally your mirror feeds a light sensor signal to the power control unit for Auto lights and Coming home lights. My mirror does not have a switch, but when the car goes in reverse it will switch off the auto-dimming function automatically.
    Try what NHN says first - I'm sure I tried it on mine and had to add the RVSL wire - mine is a B6 so B7 may not need it?
  16. #95
    Aug 2012
    12
    Thanks for that, will post back after install.
  17. #96
    27,121
    I guess if it didnt work on a B6 I dont hold out for B7 that much as same basic car tbh, as they're base network is kline, maybe it needs a can car to work on, as can on these cars is a subsystem for only certain modules, but I dont know if enabling this option auto monitors other systems for a reverse signal, guess anyone with rns & B6/7 can do this with vcds & advise.
  18. #97
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    You need to add RVSL wire and to code it,i have done the same for me;didn`t work only with the coding.
    B6 1,9TDI AVF SPORT QUATTRO AVANT
    Mods:RNS-e sat nav,Bluetooth,Rear camera,Full led interior/exterior,Cobra PCD,S4 B5 front brakes,S line body kit+S4 door blades,S line gear knob,RS4 B7 handbrake,RS6 wheels,EGR deleted,cruise control,custom leather & alcantara seats,tinted windows,A4 B7 arms & wiper blades,BV43 turbo,FMIC,custom remap(around 200hp and 368lb/ft tourque)
  19. #98
    Aug 2012
    12
    Well I got all the parts I need, just waiting for the iphone video adapter.
    The multimedia interface I got is an "ERA" one , and to my surprise it has a second input for the reverse camera, and REV12V+ IN (from reverse lights) and 12V+OUT (to RNS-E) so I don't have to build an automatic reverse-camera switcher - score!
    I connected it all up including a video in source (a STB outside the car) and the reverse camera, and after going into the on-screen menu of the ERA unit with its "mode" button and telling it that there was a reverse camera connected, everything works - it shows the TV input on the RNS-E when I select TV, and if I feed the ERA REV12V+ "IN" wire a 12v signal then the video out from the ERA switches to the reverse camera and hence of course changes on the RNS-E, awesome. Essentially this ERA unit has Woorlord's switching box built-in.
    I have two issues though;
    1) the REV12V+ "in" on the RNS-E (pin C-2) has no pin installed of course, is this an Audi part that I can get or should I just use a generic terminal that fits? The plastic connector is there as some other pins are in use, its just missing the crimp terminal for C-2. Is this a really really small male repair wire?
    2) I tested by powering the ERA and camera with a stand-alone battery. I cannot for the life of me find a 12v feed which is accessory switched. The usual suspects like cigarette lighter fuse, radio fuse etc, are all on permanently (yes I locked the car, and waited, they are permanent on). I could find some that are ignition "ON" switched (like wipers/washers), but I really want it to be wired properly and be "on" when "accessory" is on. This is to power the ERA multimedia interface and also provision for iPhone charging (USB adapter). I have the factory glove-box 6-stack CD player, and I thought I had naled the pinout on that for 12v and GND, but using those to power the ERA made the CD player behave weirdly.... Anyone have any tips for a 12v accessory-switched circuit? This the last of the B7's (built Nov 2007).
    I have not connected anything to RNS-E C-2 yet - dont know yet if the RNS-E will auto-switch to TV when reverse is selected.
  20. #99
    Aug 2012
    12
    I could not find switched accessory circuit on the fuse panel. Now I have installed a fused relay, tapped into permanent live for the relay, and switched the relay with D13 from the RNS-E, seems to be working fine. Just need to to sort out the C-2 pin issue now....
  21. #100
    Aug 2012
    12
    This weekend I installed the reverse camera, after much stuffing around getting the boot release plastic thigo out, I finally figured it out, a bit of dremel to make room for the connectors and the camera went in fairly fine, but now the DIS is whinging that the number plate light is out......can I fix this somehow, or program it with a VAG? otherwise I'm thinking I need to wire in the bulb that I removed to make the current draw sufficient to stop the DIS from complaining. Thoughts?
  22. #101
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,537
    Sounds like the new light is an LED, to stop the bulb failure warning complaining you need to add a resistor in parallel with the LED that draws enough current to make the DIS think that a normal bulb is fitted.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
  23. #102
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    639
    Thats strange because on mines it complains about numberplate bulb when both are toasted however when one is toasted it doesn't complain.
  24. #103
    Aug 2012
    12
    I have it all done now, have the camera auto-switching when in reverse, DIS error is gone (resistor), and videos are playing nicely. VIM hack is next I suppose! Thanks all for your assistance.
  25. #104
    Oct 2012
    13
    Hi Has anyone done this mod on an a3/s3? I have a 2012 S3 with the standard sat nav head unit with ipod adaptor in the glove box. Does anyone know what parts I would need? Is it just the camera?
  26. #105
    27,121
    Yes, you'd need a media adapter, wiring, cam & coding.
  27. #106
    Oct 2012
    13
    Thanks VCDS do you know part numbers for any of the parts?
    I found cameras on ebay like the one below but they say they only work for a3 upto 2009, is there a special one for 2009 up models or would this one work?
    SONY CCD REAR VIEW REVERSE CAMERA Audi A3/A4/A5/A6/A6L/A8/Q7/S4/RS4/S5/S6/RS6 | eBay
  28. #107
    Oct 2012
    13
    thanks NHN do you have any part numbers for them? I have found the cameras everyone talks about on ebay but they say they are only for A3 upto 2009. Is there different ones for the newer models or would they still work?
  29. #108
    27,121
    Do some research mate on the forum, as all the info is readily available, just spend some time reading & learning please.
  30. #109
    Nov 2012
    Hi
    Is there anyone that can fit a reverse camera set up for me?... I have a standard RNS-E unit already, but need all the other gubbins, adaptors, software etc..... It would be going in a 2000 Allroad 2.7T AUTO TIP :-)
  31. #110
    27,121
    Yeah wing me a PM with your location, should be ok mate.
  32. #111
    Rick_RS4's Avatar
    Dec 2010
    25
    what coding did you use? i cant get mint to auto switch to cam
