JMB RetrofitsAH Fabrications
Results 1 to 11 of 11
    Oct 2009
    Hull
    1,442
    1.9tdi operating temp
    what is the normal running temp of the 1.9tdi ?
    mine very rarely gets above 70 degrees
    always sits at 70 and when stuck in traffic it will rise to just below 90
    ive heard they are supposed to run at 90
    cheers stu
    Lancaster
    1,788
    Yup, 90 is right.
    Your thermo stat could be stuck open like my 2.5 one
    To do: None yet.
    Oct 2009
    Hull
    1,442
    thanks for the reply
    cant see it been the stat unless its just sticking a bit as it warms up pretty quickly!!!
    ive had a car with a stat stuck open and it wouldnt get warm at all lol
    what other things is it worth checking ?
    where does it get the temp reading from ? is it the temp sensor that is round the back of the head ?
    Lancaster
    1,788
    Not sure where the sensor is on the 1.9tdi, I'd like to know this my self as our lasses is well out!
    To do: None yet.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    There's a thread on the CTS (coolant temp. sensor) HERE.
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    yep as above, mine runs at 90 all day long
    Oct 2009
    Hull
    1,442
    thanks for the replies
    i think im going to change the stat and the sensor as they are cheap enough!!
    just a thought could the sensor cause starting issues ? mine will turn over for a fair bit before firing other and sometimes it will fire straight away!!
    Lancaster
    1,788
    It can do yes, and use more fuel.
    To do: None yet.
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Mine was doing this ,
    and i also thought that it wouldnt be the thermostate as it would get to 70 no problems but after changing the ecu temp sensor (which also does the guage ) i changed the thermostate and housing and hey presto upto 90 and stays there whatever happens .
    2,180
    Get the genuine audi one, I fitted an after market stat from euro car parts and with normal motor way driving I always get around 75, but when in traffic it does up to 90. I'm going to rip it out next weekend and fit a genuine one.
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Quote Originally Posted by B5NUT View Post
    Genuine all the way , i also fitted the plastic housing as i always do with any plastic water component on any car as they quite often go brittle and leak when not renewed .
