Sky InsuranceVolks Autos
Results 1 to 8 of 8
    mattyboyc's Avatar
    Sep 2009
    1,167
    Air con not cold.
    Hi all, recently replaced my high pressure sensor on the air con as the "ECON" light was permenatly on this sorted the problem and the pump turns on and off and the screen demist all works fine,however going to work last night was quite warm so i popped on the air con only to find there was not temperature change atall between air con on or air con off, tested again this morning and again still can't feel a difference, i have a gas level tester and this shows that the system is charged,i don't have a temperature probe and for some reason "ER INDOORS" wasn't over keen on be poking either my daughters or the meat thermostate down my heater vents to get a reading, so my question is this, has anyone else sufferd the same after changing anything or does anyone know where i can get a cheap probe before i book it in to have the system emptied and re-gassed.
    Any help appreciated as always,
    Matt
    A4 AVANT 1.9TDI 130 SPORT:
    18" RS6'S//TWIN EXHAUST//ALLARD EGR DELETE//AERO WIPERS//B7 KEYS & ENGINE COVERS//BLACK OPTICS //FRONT & REAR S-LINE BUMPERS//TAILGATE SPOILER//S4 HEADLIGHTS,GRILLS & DOOR BLADES//RS4 RARB & PEDALS//FRONT,REAR & FOOTWELL AMBIENT LIGHTING//PUDDLE LIGHTS//FAN JETS//MEDIA SYSTEM//T.V//7" HEADREST MONITORS//REAR BLINDS//REVERSE CAMERA// CRUISE & DIS
    Lancaster
    1,637
    I had a problem where adjusting the temp made no difference what so ever.
    One of my motors on the heat flap had stopped working. I popped it off and move it by hand, but the motor back on and it all worked.
    To do: None yet.
    simon.m's Avatar
    Oct 2009
    2,746
    the only thing i can think of is the cold flaps not opening im having the same problem it feels colder with the eco button on than with it off
    Lancaster
    1,637
    Is there a temp difference between drivers and passenger side? Say if you set it to 17degs on both sides. Is one side warm one cold? Worth a test.
    To do: None yet.
    mattyboyc's Avatar
    Sep 2009
    1,167
    Quote Originally Posted by simon2004 View Post
    It's not just me then, mines the same but i thought it was my imagination.
    mattyboyc's Avatar
    Sep 2009
    1,167
    Quote Originally Posted by BlackQuat View Post
    Where are the heat/cold flaps, i can hear motors moving when i push the relevent buttons if that makes any difference.
    simon.m's Avatar
    Oct 2009
    2,746
    ha i was starting to think when the eco light is on that meant the aircon was on as it was colder lol
    if you take the clove box out you can see them all its the closest one to you i think is green or blue i still have to do mine will have a go tomoz
    Lancaster
    1,637
    Quote Originally Posted by mattyboyc View Post
    Where are the heat/cold flaps, i can hear motors moving when i bush the relevent buttons if that makes any difference.
    Take out the lower dash cover and look up where the clutch switch is. There is a motor into the side of the unit. Get under have a look and get someone to alter the temp from cold to hot on that side. If it doesn't move thats the problem.
    To do: None yet.
