EM TuningVolks Autos
Results 1 to 19 of 19
Thread: 3 into 2.5
    Mar 2010
    63
    3 into 2.5
    anyone know whether the backboxes of a 3 litre tdi cab will fit the 2.5tdi,along with the bottom apron? got behind a 3 litre today and looked much better than my 2.5.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,685
    The 3.0TDi is a B7 model so has a totally different rear bumper.
    I'm sure the back boxes would fit - but all you would need to do is a get a rear valance with the exhaust cut outs and weld some Powerflow tips on.
    A4 nut's Avatar
    wolverhampton
    352
    Arnt they the same as the 1.8T look at my avatar
    Ps james cabs did not change
    Hope the people that took me DIE
    Mar 2008
    Dorset
    13,685
    Does the OP have a cab? It doesn't say so in his post unless I've misread it.
    A4 nut's Avatar
    wolverhampton
    352
    I read it as will the 3.0 fit the 2.5 take it as the same cab, but good question?
    Mar 2010
    63
    yep,mines the b6 cab 2.5.the apron on the 3 tdi maybe the same as the 1.8 but the exhaust isnt,they still point down as do mine but they are more noticeable as they protrude from the apron whereas mine are hidden.
    Mar 2008
    Dorset
    13,685
    Yeah you could be right, it could be read one of two ways! I'll sit back until it's confirmed
    A4 nut's Avatar
    wolverhampton
    352
    I would not mod to more downward facing pipes would be looking for some nice chrome tips think that james steps in here
    Mar 2008
    Dorset
    13,685
    Powerflow tips FTW! You can probably keep your existing valance then ??
    Mar 2010
    63
    rather the soot went straight down rather than annoy people behind me
    Mar 2008
    Dorset
    13,685
    Does yours throw out smoke then? I've got a remapped 2.5 (180) and it doesn't throw out any soot......
    Mar 2010
    63
    under heavy acceleration it throws a bit out yes but most of the time i nurse it so when on the occasions i do boot it obviously it shows its a diesel.
    A4 nut's Avatar
    wolverhampton
    352
    No problems then! new tips should be the cheapest and best looking way to go.
    Mar 2010
    63
    guess i will look out on ebay for a apron then,are the b6 and b7 the same or do i have to stick to the b6?
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    cant you just chop off the down pipes and weld on new chrome tips? change the apron?
    Mar 2010
    63
    need to change the apron as mine doesnt have cutouts for the exhausts,dont want to attack it with a saw and make do,would rather buy the correct item.
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    946
    Get yourself a new cut-out valance and then visit a Powerflow delaer - old ends cut off and new ones welded on - quality job over some cheaper DIY bolt-on ones from the high street or retail park!
    They have a choice of sizes - I went for the 100mm to fill the valance hole - be careful with small children - they can fall in if not properly supervised!!
    Other Saloon pictures.....<<Linked Here>>
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Mar 2010
    63
    that looks a lot better than this and is the kind of look i am after................
    Mar 2010
    63
    dont suppose anyone knows what the part number is for the valance with cutouts for the cab is?even better is if someone has got one knocking about that they want shut of.
