anyone know whether the backboxes of a 3 litre tdi cab will fit the 2.5tdi,along with the bottom apron? got behind a 3 litre today and looked much better than my 2.5.
yep,mines the b6 cab 2.5.the apron on the 3 tdi maybe the same as the 1.8 but the exhaust isnt,they still point down as do mine but they are more noticeable as they protrude from the apron whereas mine are hidden.
under heavy acceleration it throws a bit out yes but most of the time i nurse it so when on the occasions i do boot it obviously it shows its a diesel.
Get yourself a new cut-out valance and then visit a Powerflow delaer - old ends cut off and new ones welded on - quality job over some cheaper DIY bolt-on ones from the high street or retail park!
They have a choice of sizes - I went for the 100mm to fill the valance hole - be careful with small children - they can fall in if not properly supervised!!
dont suppose anyone knows what the part number is for the valance with cutouts for the cab is?even better is if someone has got one knocking about that they want shut of.
