Results 1 to 9 of 9
    9
    A4 (B6) CAB 3.0 v6 - Sluggishness and part throttle surge
    Hello all.
    Please forgive me if this has been covered and solved before. I've searched the threads but I can't see a 'solved' answer to my slight problem.
    I own a manual 2003 Audi A4 3.0 V6 Cabriolet (B6). I am having some strange things happening when I accelerate.
    Be it warm or cold, I get a very slight hesitation/sluggishness when I set off as I press the peddle down, this happens only occasionally. It starts off like it's driving through a strong wind but it does not feel lumpy of juddery. It lasts thorugh to about 3500 rpm and no matter how much juice I give it the sluggishness continues until after a few seconds when the engine suddenly picks up and the car roars off.
    The 'surge' part to this threads title is this. When I'm crusing and I press the accelerator 1/3rd - 1/2 way down the car seems to pick up with more acceleration in this position than at WOT.
    This is my first Audi, it's a lovely car but this is getting a little annoying.
    No engine lights what so ever. It's also had a recent big service at Audi that included the cam belt.
    It was doing it before it went in, but I totally forgot to ask them about it.
    The previous owner had a coil pack go on him and he gave me a spare one just in case. I thought that if a coil pack was failing the engine lamp would come on.
    I run it on 97RON with occasional REDEX shots. It's done 58k.
    I called Audi parts yesterday but they would not let me speak to a technician. I suggested a coil pack and they agreed it might be as the previous owner had a pack go on him, so he replaced it with a Europarts pack - he also left me a spare. Audi service told me that it does not sound like a coil pack...! 'Confused you will be'
    They also told me it would cost me 50 for them to diagnose it... I might buy a BMW again, they never charged for diognosis.
    The coil packs are the red topped ones.
    Can anyone help me?
    Many thanks!
    simon.m's Avatar
    Oct 2009
    2,746
    hi there id say buy this and test it your self its vag-com what every one uses for audi it works grate
    it found my faults with no problem and one i did not no i had hope it helps
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    9
    Hello, many thanks for your reply. I'll take a look at that, many thanks...
    It would be great to know if anyone has had any of these symptoms though...
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Get a diagnostic scan - this should show up anything obvious. Perhaps a fellow forum member can help out - where are you based? Getting your own VAG-COM cable soon pays for itself - even the expensive fully licensed one from Ross-Tech! Your other suggestion, Beamer vs Audi......... I have both and the Audi wins easily I'm afraid for me.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Apr 2008
    7
    Hi,
    Did you find a resolution to this problem?
    Cheers.
    Mar 2009
    33
    Don't the 3.0 v6 have issues with carbon buildup on the intake valves? i'm sure there's lenty of threads on this and the sluggishness was caused due to that. It's a do-able job to clean them without stripping the heads off, you only need to remove the intake manifold on the top.
    Iyole's Avatar
    N/A Rools
    Feb 2011
    Cape Town; South Africa
    69
    Quote Originally Posted by Leea4tdi View Post
    My thought xactly...... Audi RSA spent 8 months trying to resolve a similar issue on my Cab only to find it was a valve in the intake manifold that had
    carboned up. There is a sensor that uses this information to adjust air/fuel etc. Audi replaced just about every related electrical sensor on Cab before
    ending up stripping and cleaning the Intake Manifold (7 Hrs Labour) No Parts.... Sorted
    Jan 2011
    686
    Does the carbon buildup affect 2.4s to ?
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    As mentioned the first step to get to the bottom of anything like this is a diagnostic scan, anything else is just like plucking ideas out of the sky in honesty!
    Either bite the bullet and buy a cable yourself, of pay for a scan. I'm sure most garages would knock the cost of that of any repair work.
