Ok due to a change in plan I have an RNS-e and bits up for sale, I have everything you need for it to go into an A4!! So you can buy it all, or separately!
RNS-e Unit
This is a 8E0 035 192 T Audi A4 Europe, MY 2008, 8E B7, sw 0650
It has AUX in activated, in excellent condition, comes with a 2010 map and set of Audi discs.
Includes Fakra GPS antenna, and security code.
£500 fully insured posted to your door.
RNS-e Loom & Keys
This is NOT an eBay cheap one, this is a Kufatec loom (http://kufatec.com/index.php?main_page=product_info&cPath=144_87&products_id=611) a $76 loom!
It is set up for Bose (although this can be adjusted) CD Changer and telephone, although you do not need these, they can be added later. It includes the 4 Keys to take out an Audi unit and put in the RNS-e.
Also includes the diversity antenna adapter
£50 fully insured posted to your door.
Double Din cage
This is for if you have a single Din cage in your car, and need to update to double Din for the RNS-e part number 8E0 858 0005 F.
Will come complete with PDF fitting instructions.
Aux in for IPod/MP3 etc
This is for adding to the RNS-e via the multimedia socket on the back (possible on symphony 2 as well?)
It includes the OEM part number 8J0 035 475 which is an AUX socket to plug a 3.5mm jack into and has a cover over the top saying AUX. You can mount this anywhere in your car.
Comes with the multimedia plug with correct wires for RNS-e, just attach the wires to the AUX socket and you have Aux in for your RNS-e!!
£30 fully insured posted to your door.
Memory cards for use in RNS-e
2 available (there are 2 slots on the RNS-e for memory cards) each is 4GB in size, and is the correct SD Card for an RNS-e. These are not SDHC cards, as these dont work in an RNS-e so are more expensive than standard cards, and fairly hard to come by!.
1 new in packet £18 posted
1 new but not in packet, but with music on to test RNS-e £17
Both for £32 fully insured and posted to your door.
Or for the whole lot, ready to go, with all extras listed above, delivered and insured for £625.00
Pick up also available from Bedale, North Yorkshire
RNS-e Unit
RNS-e Loom & Keys
Double Din cage
