EM TuningBadger5
    SMc
    SMc's Avatar
    Jul 2004
    Glasgow
    135
    headlight bulb removal on A4....
    Why does it have to be so bloody difficult? I can't get the plastic cover off at the back of the headlight unit....trying to change the dipped headlight.....easy enough to remove the air box housing and unclip the plastic cover but the cover just wont come off! Even the haynes manual just says 'unclip and remove plastic cover' but its still connected to something as there is no way this thing is coming off!!
    Anyone else had this and got any idea other than removing the whole air box!!
    On my 3rd Audi.....my latest PROJECT...... a 2002 A4 1.9TDi Avant Sport.... wrapped matt white with 19" VMR matt black wheels.
    simon.m's Avatar
    Oct 2009
    2,746
    its easyer to remove your headlight mate 5 min job and should not change the light angle.
    plus you will not get your hands in to pull the bulb out
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    if you take the headlight out, only lossen the bottom bolts, do not take them all the way out
    sutton coldfield
    440
    Quote Originally Posted by SMc View Post
    Yeah Defo; need to remove, H,light, just un-screw both top torx from slam-panel, then just loosen ! the two at the back of, H,light just slide the whole unit forward !!!
