    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    Brake pad wear indicator
    I had the car serviced & MOT'd yesterday. The garage told me the car needs new front discs & pads. I'm not wholly surprised. The discs are the originals, so have done nearly 82,000 miles from new. The pads were changed at 39,000 miles, so the car has done 43,000 on this set.
    However, the garage said the pads only had about 1mm left on them, which makes me wonder why the pad wear indicator hasn't flashed up. I haven't had a chance to do my own visual inspection, but would have thought the indicator would have gone off by now if the pads were that thin?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    iyrix's Avatar
    Mar 2010
    427
    Well on my old 306 the wear indicator was on 1/2mm. Not sure if that helps. but i know when the light came on i had like a few hundred miles and then i got grinding...
    Audi A4 TDi 130 Sport
    technics100's Avatar
    Feb 2004
    Co Antrim
    772
    Sometimes, garages will use pads without the sensor and then short out the sensor plug with a wire, have a look at the back of the calliper.. I just disabled the wear indicator on my wife's Touareg last night as all the pads had loads of depth left..
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    Lancaster
    1,626
    I can vouch for that, our lass managed to buy some pads for her A3 that didn't have sensors. So i just shorted the pins out. I check the cars regular anyway.
