JMB RetrofitsEM Tuning
Results 1 to 12 of 12
Thread: anti roll bar
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Question anti roll bar
    the rear one for all its worth.
    How many of you have had yours changed? iv got this slight knock from the rear of my car, for the love of chocolate i cant find what is making the knock, iv been under there with the car up on the ramps and push and pulled and crow bared everywhere for the knock, but i cant fine it, iv been told the anti roll bar could be stuffed, iv taken it off, all seems ok there, the plastic sleeves look ok, iv changed the D bushes, everything seems to be solid under there, iv even dont the drop links,
    does the anti roll bar just lose its strength over time and bend more than it should after so many years and miles?
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Probable not much help to your question but If you thinking of putting a new ARB on then you may aswell go for the RS4 ARB, costs around 75.00 with all the fixings and the difference in ride in amazing.tightens up the rear roll loads and makes the cornering fell alot more planted.
    silversurfer's Avatar
    Jan 2007
    221
    I upgraded to the rear RS4 anti roll bar which has made a big difference, well worth doing for the money..
    Is the knocking only when you go over bumps?
    itsmeagain's Avatar
    1.8T Sport Cabriolet
    Mar 2010
    West Midlands
    435
    I upgraded to the rear RS4 anti roll bar on my convertible which has made a big difference, well worth doing
    Audi A4 1.8t sport convertible, Full Grey Leather Interior, Ambient Light Pack, Polished Forge FMCL007P Diverter valve, Green Cotton Filter, 100mm Tail pipes, Rear RS4 ARB, Interior Xenon White LED's bulbs, Xenon White LED number plate bulbs and side lights, JBS Auto Designs stage 1 remap, RNS-E and OEM Bluetooth, Remote roof module, OEM Wind Deflector, B7 rear lights, HID lights.
    Jan 2009
    23
    Have you got twin rear pipes?
    Had this on mine today and found the support bar between the two pipes had snapped on one side
    Turkster's Avatar
    Dec 2007
    2,723
    Quote Originally Posted by silversurfer View Post
    The knock seems to be on take off when everything is under tension, not on bumps
    Turkster's Avatar
    Dec 2007
    2,723
    Quote Originally Posted by jones_g View Post
    yes, my car is a 2.5 TDI Quattro Sport, can you take a photo of your snapped bit ?
    Turkster's Avatar
    Dec 2007
    2,723
    Quote Originally Posted by J7USS View Post
    I will look into this as a new bar for my car is 50 or so, iv been told this info before and now i will most certainly investigate this option see as you and the others are waving it at me,
    Jan 2009
    23
    Quote Originally Posted by Turkster View Post
    Mines a 1.8T so don't know if you'll have the same.
    I have no photo's, but if you look underneath the rear, in the middle On my exhaust the 2 pipes come up the middle of the car then split off from eachother to go to each side of the car. Where they split out in the middle, there is a small brace bar between the 2 pipes, about 8 inches long, mine had snapped on one side, ironically after I took it to have the RS4 ARB fitted. They had to drop the exhaust off to do it so I think they may have snapped it then
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,257
    i have a knock too but its only when you set off with a bit of welly i put it down to the quattro system at the rear but the idea of the exhaust bracket broken is feasable. is yours a quattro also?
    Turkster's Avatar
    Dec 2007
    2,723
    Quote Originally Posted by swarcup View Post
    yes its a Quattro its going into Audi today so they can take a look at it
    itsmeagain's Avatar
    Mar 2010
    West Midlands
    435
    Have you not got any good independent audi specialists over your way. Cause Audi are going to take all your cash before anythings fixed
