Monster MotorsportEM Tuning
Page 1 of 2 12 LastLast
Results 1 to 40 of 55
    Lancaster
    1,629
    RNS-E 2001 B6 - Which do i need?
    I've decided the Sony head unit in mine has to go.
    It's so out of place. I want my autochanger back and working, but i want mp3. So RNS-E seems the best option.
    I've had a look around and they seem to be sat nav too. Is this correct.
    I assume I'll need a different cage unit for the double din and a different climate control unit which sits lower.
    I have Vagcom, so can do the nessecery there.
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    this page/forum is your friend: Audi Forum RNS-E Quick Links
    start by having a read of this: RNS-E Retrofit
    everything you need to know is in the links above
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    vrbob's Avatar
    Jun 2007
    Southampton
    2,279
    I got my RNSE of Ebay just be cautious about who you buy from as most are from germany even if they say UK on Ebay.
    I think PJMSpeedy can get them for about 450 so you may wanna drop him a PM. I didnt need VAGcom to fit mine as its pretty much plug and play if your car is already double din.
    Also when you buy the RNSE check the model number as this will tell you how old the unit is and if its an A4 model eg :
    8E0 035 192 C Audi A4 Europe, MY 2004, 8E B6
    8E0 035 192 D Audi A4 Europe, MY 2005, 8E B7
    8E0 035 192 E Audi A4 North America, MY 2005.5, 8E B6
    8E0 035 192 F Audi A4 North America, MY 2006, 8E B7
    8E0 035 192 G Audi A4 BNS 5.0
    8E0 035 192 H Audi A4 Europe, MY 2006, 8E B7, with SDS
    8E0 035 192 J Audi A4 North America, MY 2006, 8E B7
    8E0 035 192 K Audi A4 Europe, MY 2007, 8E B7, sw 0500
    8E0 035 192 M Audi A4 BNS 5.0
    8E0 035 192 N Audi A4 Europe, MY 2007, 8E B7, with SDS
    8E0 035 192 P Audi A4 North America, MY 2007, 8E B7
    8E0 035 192 Q Audi A4 Europe, MY 2008, 8E B7
    8E0 035 192 R Audi A4 Europe, MY 2008, 8E B7, with SDS, sw 0650
    8E0 035 192 S Audi A4 BNS 5.0
    8E0 035 192 T Audi A4 Europe, MY 2008, 8E B7, sw 0650
    8E0 035 193 Audi A4 Europe, MY 2008.5, 8E B7, with SDS
    Most of the RNSE`s on Ebay come bundled with the other bits you need to make it work but make sure it has : the GPS antenna, Stereo removal keys x 4, Wiring loom adapter, an Audi map DVD (as new as poss and preferably an original disc).
    Lastly if the screen looks scratched (the anti gare coating wears off) this can be sorted so if you can get a cheaper one that this has happened to you can buy some Meguair PlastX (http://www.cleanyourcar.co.uk/engine.../prod_283.html) i used it on mine and it looks as good as new now.
    Hope that helps
    Mods : Revo Stg 2 & Select+, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    bob, you could do with pluging in to vagcom if you get chance mate, some bits would deffo need coding, speed sensor etc would need checking etc do you have it all coming up on your dis, audio through the correct side etc.
    would be worth plugging in to check all mate.
    LOTS DONE, LOTS SPENT !!!!
    vrbob's Avatar
    Jun 2007
    Southampton
    2,279
    Yeah i do wanna plug in with VAGcom as it still software version XX which i know means it has been hacked. Although i had no idea there was that much you can play with in the RNSE will defo need some guidance.
    It dislays the radio/mp3 track on the DIS but i dont get any sat nav directions on there which i know you can from reading others posts. But i thought this maybe because i dont have full DIS yet.
    I also think the RNSE thinks i have Bose as it wont let me adjust some of the audio settings i can see in the manual. My VAGcom cable should be here next friday so will try and have a go then.
    I have loads of jobs on the list for when the cable comes and i am off on Holiday for 2 weeks Sunday so will be a busy boy. So heads up for Friday/Saturday as i am sure there will be some urgent requests for help once i start playing with VAGcom
    26,721
    Stick a dvd with FW 650 in & do a forced FW update with use of vagcom & this will install 650, as I've had to do before on a unit I bought with XX showing at current FW version, did this months ago & to date not a single issue & shows the correct data in the Info section for the RNS/DVD info.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,279
    i have an original 2008 maps disc and a copy of 2009 which seems to work ok.
    So i guess i put the maps disc i the RNSE and then use VAGcom to make it do a firmware update?
    26,721
    There's an echo in here
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    in here........in here...............in here.......... lol
    Lancaster
    1,629
    Cheers chaps! I'll start putting a few pennies away then. I suppose if i go back to a oem style radio. It's be rude not to have steering wheel controls too?
    Lancaster
    1,629
    I'll start getting the bits i need together soonish. I assume I'll be needing a double din mount and a different climate control unit. Are these hard to come by. I saw the mount on ebay at 50quid. Which seems abit steep.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,698
    1wheel's your man for this, it's well outside of my knowledge range! But my understanding is that the existing cage (assuming you have double din already) can be trimmed to allow the same climate control unit to just sit lower down.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    single to double din requires a new double din cage ( 50 is about right ) you dont need to buy a new climate unit, the one you have needs a few mill trimming off either sides and slots in below the rns-e perfectly ( you were close james ). an easy mod but allow a couple of hours to complete, its not a two minute job.
    if your going down the route of multi function steering wheels ( assuming you havent already got one ) then you need to find what module and slipring you have, plus whilst your there you might aswell add cruise control. lol so yes get saving lol
    N80KRR's Avatar
    Feb 2009
    West Sussex
    176
    I've already got a rns-d, would I be able to plug and play with a rns-e?
    I have no money and now this:
    which evidently needs a lot of money.
    Lancaster
    1,629
    Quote Originally Posted by 1wheelonly View Post
    I currently have an L module, which i beleive does support MFSW, but i have a Q as well incase. I fitted cruise control and DIS last week, whilst having a play.
    So i just need to get a double din cage (currently running single din) and trim down my climate control.
    I'm sure i can manage this fine.
    Then it's the expensive bit.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    youll need the correct slipring too for multi wheel
    Lancaster
    1,629
    I'll probably be doing that at a much later date, cheers for the heads up though.
    Saving time!
    Lancaster
    1,629
    Started reading through and thinking about which to get. I've seen one ending in T will it work in my 2001? I am abit lost tbh!
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    Quote Originally Posted by BlackQuat View Post
    explain yourself a bit more matey, whats ending in T module, rns-e ??? more than one subject has gone on here lol if its the rns-e ending in T then yep thats fine, theres a list been posted at the top of this page by VRBOB
    Lancaster
    1,629
    Yeh the RNS-E, Sorry being abit useless lately! I've got my eye on one. So fingers are crossed.
    Sorted my heated mirrors today too, fitted a heated mirror and now they work. Grand!
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    i did mine yesterday, ready for the summer hey lol
    Lancaster
    1,629
    Better late than never!
    Lancaster
    1,629
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=300410634922
    Right then!
    It'd seem i need a gps atena and a cage.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    blacky is that one you listed the one youve won ?????
    Lancaster
    1,629
    Yeh, worries now that its no good. Please tell me its ok.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    if i read the listing correctly youll also need an A6 !
  28. #27
    Lancaster
    1,629
    lol!
  29. #28
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    that wont fit your car blacky
  30. #29
    Lancaster
    1,629
    Ah well live and learn!
  31. #30
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    you wont loose out mate, clean up and relist them, seperately, youll probably make some, put towards the CORRECT ONE !!! lol i know some one whos got some a3 rear lights, are you interested lmfao
  32. #31
    Lancaster
    1,629
    Strangely enough, I was just browsing ebay. Saw a A6 Allroad rnse and it's different to that one, the width of the unit at the top is alot wider.
    A6
    The one i bought
    A4
    I wonder!
  33. #32
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    wait till it comes, i can see what your saying, providing the guy used the actual one in his listing picture ?????
  34. #33
    Lancaster
    1,629
    Well yes, very valid point! But he does talk about how you can't see the scratch on the screen in that pic. Not that its not the actual picture.
    AS you say, wait till it comes. When you check the pictures. It does seem very much A4 style.
    Also the A6 one doesn't has a chrome bar under it, but the one ibought does. I do hope its the one in the pic! lol
  35. #34
    vrbob's Avatar
    Jun 2007
    Southampton
    2,279
    If you did get the A6 model RNS-E you can buy an A4 facia for it like this one http://cgi.ebay.co.uk/Audi-A4-origin...item335b74a994
    Not sure how difficult they are to swap over and if it is worth it in the long run but thought i would mention it
  36. #35
    Lancaster
    1,629
    I saw that Bob, apparently its like a 4hour job for someone whos done it before!
  37. #36
    vrbob's Avatar
    Jun 2007
    Southampton
    2,279
    4 hours thats alot so probably better off flogging it and buying an A4 one then, Hopefully you will be lucky and it will be the right one this time.
  38. #37
    26,721
    It takes a while to remove all the parts patiently, its not for faint hearted, but certainly not impossible, taken them apart many times.
  39. #38
    Lancaster
    1,629
    It is an option then! I can't help but think, it looks right though!
  40. #39
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    nige, you were my example. remember reading youd done the chrome nob conversion for people and it was a big job.
  41. #40
    Lancaster
    1,629
    Had it confirmed the one in the photo IS the one I'm getting.
