JMB RetrofitsAH Fabrications
Results 1 to 27 of 27
Thread: in car temp
    simon.m's Avatar
    Oct 2009
    2,746
    in car temp
    so as iv not had climate control before can any one tel me if 18c is the lowest it goes down to before it says low.
    just seems strange that i cant got to say 15c
    wallacr's Avatar
    Nov 2003
    241
    I know, it's a right pain. They did change it to 14 in the B7 I believe. I tried a B7 module in my car and everything worked ok except for rear heated windscreen, so I guess it's a slightly different setup in the newer climate control models.
    A4 B6 1.9 TDI SE (130)
    Standard Options: Cruise Control | Ambient Lighting | Lighting Pack | Parking Sensors
    Retrofits/Mods: 19" RS4 Reps | Chipped | LED Daylight Running Lights | RNS-E | Bluetooth | TV Tuner | Glovebox CD Changer | S4 Electric Folding Mirrors | Spax Coilovers | Stainless Steel Duplex Exhaust | K&N Induction Kit | Tinted Windows | MFSW | SDS | Vortex Kit | Coming Home Lights | Auto Lights | LED Rear Lights
    Planned: RSAP | Rear View Camera
    mikeh126's Avatar
    Preston, UK
    152
    Same as mine - 18c or 64f, and then it goes to Lo.
    When Lo is showing, I presume the air con (cold) unit comes on, without measuring the temp inside the car.
    2003 A4 Avant 2.5TDi 180 Quattro Sport in Light Metallic Silver, Remapped to 220 by ProTec Motorsport, RS4 18" x 8J reps, Falken F452 tyres, 10mm H+R Spacers, Matt Aluminium Mirror Covers, Heated Mirrors, S4 Door Blades, Continental TS830p Winter Tyres on 5 star 17" Sport Alloys
    wallacr's Avatar
    Nov 2003
    241
    Quote Originally Posted by mikeh126 View Post
    Yes exactly and it doesn't take too long to get too cold, I generally have mine on 18 or Low and not always on Auto, sometimes I'll just have the fan on 1 bar, that seems to help a bit
    simon.m's Avatar
    Oct 2009
    2,746
    thats what i thought so its 18c or frezzzzzzzzzzzzz
    wallacr's Avatar
    Nov 2003
    241
    Quote Originally Posted by simon2004 View Post
    Pretty much
    chrisash32's Avatar
    Manchester
    575
    hmmm.. when mine is on low it doesnt seem to freeze.... in fact it still feels quite warm.. think i may have an AC issue
    wallacr's Avatar
    Nov 2003
    241
    Quote Originally Posted by chrisash32 View Post
    Sounds like there's a problem, it could just be gas, it could be the connector has corredded like it did on mine or it could be the compressor.
    Under the bonnet on the back left there are two a/c pipes, when your engine is on and a/c on low one should be freezing cold and the other warm, if not it's defo one of those above I would think
    chrisash32's Avatar
    Manchester
    575
    cool, will give that a try, thanks
    simon.m's Avatar
    Oct 2009
    2,746
    i have ac problems my self think the compressor is not kicking in
    wallacr's Avatar
    Nov 2003
    241
    Hope you both get them fixed soon
    chrisash32's Avatar
    Manchester
    575
    is there any way i can test the components with vag-com??
    wallacr's Avatar
    Nov 2003
    241
    There probably is, oddly it showed no faults when mine went, but someone else who's more clued up on the in's and out's of vag-com will be able to tell you, perhaps in the VCDS forum if not here.
    simon.m's Avatar
    Oct 2009
    2,746
    im told you can find it with vag.com and i no audi can pin point it or so they say.
    A4 nut's Avatar
    wolverhampton
    352
    If your air con isnt working then the red econ light stop on and stops the compresser from working, you need vag com to read the fault code and hopfully its a pressure switch.
    Hope the people that took me DIE
    wallacr's Avatar
    Nov 2003
    241
    Quote Originally Posted by A4 nut View Post
    Am I right in thinking that's just if it's a gas/pressure issue? As I never had that happen on mine.
    simon.m's Avatar
    Oct 2009
    2,746
    i changed my pressure switch and the light whent off but still dont work and i tryed toping it up too and still nothing but some times the light dose not go off.
    defsix's Avatar
    149
    Mine goes down to 16c then low.. with cold air blowing then. Didn't work up until a few days ago changed the G65 Thrust Sensor ( thanks pjm ) 5 minute job to fit. perfect.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Vagcom will detect most aircon fault codes, but it obviously won't tell you if it's low on gas! Chris it sounds like yours is probably 'a bit' low on gas, but not low enough to cause the compressor to switch off. It does this to protect itself as the gas supplies the lubrication, when the compressor isolates itself is when the ECON light comes on.
    The ECON light is usually either the high pressure switch or low on gas. If it's low on gas get it pressure tested before refilling as if there's a leak you need to sort that out first.
    I think all B6's only go as low as 18, (but maybe some very late ones go to 16...?) and the B7's go to 16. A B7 climate control can be retrofitted, but as mentioned requires a mod to keep the heated rear screen working, Woorlord can help you with this. The B6 aircon is just notoriously inefficient! For some reason an Audi 18 feels warmer than other manufacturers! Mine will blow lovely ice cold air when set to LO, but as mentioned it's a PITA as you have to turn AUTO off or the fan goes flat out - and then when eventually you get too cold and have to raise it 18 it blows hot air!
    At the end of the day though, it will keep you cool if it's working well
    wallacr's Avatar
    Nov 2003
    241
    That's good to know, wish I'd kept that B7 unit now, ah well
    simon.m's Avatar
    Oct 2009
    2,746
    Quote Originally Posted by defsix View Post
    what is the G65 Thrust Sensor and where is it
    Mar 2008
    Dorset
    13,856
    It screws in the N/s of the condenser, its a pretty easy change and you shouldn't lose any gas in doing it:
    66
    Just for info, my '01 B6 only went to 18. This '04 goes to 16. '04 seems to be the year as my TT too only went to 18.
    '04 A4 Avant 1.8T Quattro LE - Retrofitted: RNS-E, Bluetooth, front centre ambient lights, full DIS, cruise control, alcantara steering wheel, more to follow....
    Gone but not forgotten - '98 A3 1.6 SE, '01 S3, '01 A4 1.8T Quattro SE, '02 TTC 225, '04 A3 3.2 Quattro S-Line DSG
    simon.m's Avatar
    Oct 2009
    2,746
    thanks james thats the bit iv change and still not working
    Mar 2008
    Dorset
    13,856
    Have you had the system pressure checked?
    simon.m's Avatar
    Oct 2009
    2,746
    well i got my self a halfords top up one and put it on and it says it was fine so i have a new bottle of gas and gage but no ac
  28. #27
    defsix's Avatar
    149
    Just
    slide out the passenger headlight and it's there on the left, 2 spanners and it's off. No gas loss, but check to make sure the rad piece is lubricated , this means you've plenty of gas with oil still circulating.
