Volks AutosEM Tuning
Results 1 to 19 of 19
    Mar 2010
    6
    2004 cabriolet roof problem
    hi,can anybody help?the roof goes down as it should,when coming up the windows go down,the hood cover comes up then the hood starts to lift then stops as if it,s still locked in,any info greatly appreciated.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    do a full manuel reset and lock out its in your manuel, this should reset all the system / sensors then try again
    LOTS DONE, LOTS SPENT !!!!
    Mar 2010
    6
    hi,done this 3 times,still no good,checked sensors,all working,thanks
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    do you have access to vagcom, plug in and check
    Mar 2010
    6
    i,ll get it on vagcom 2moz,thanks
    Dec 2008
    Blackpool and Watford
    133
    When you have a look on Vagcom, 26 for the roof, the measuring blocks should tell you what position the sensors think they are in
    VAG-COM Label File
    ; Audi A4 Cabriolet (8H)
    ; Component: J256 - Convertible Top (#26)
    ; P/N: 8H0-959-255-???
    ; includes measuring blocks
    ; created on 21/Jul/2006 by Sebastian Stange (Sebastian@Ross-Tech.com)
    ; last modification: 27/Oct/2007
    ; requires VAG-COM 402.3 or newer
    ; measuring blocks
    001,0,Convertible Top Status (Actual)
    001,1,Convertible Top,Control Switch,Range: Open/Closed/Not Oper./Not OK
    001,2,Switches &&,Positions I,See Label File
    ; xxxxxxx? = Convertible Top Open Position Switch (F171)
    ; xxxxxx?x = Convertible Top Closed Position Switch (F202)
    ; xxxxx?xx = Convertible Top Lock Switch Open (F294)
    ; xxxx?xxx = Convertible Top Lock Switch Closed (F295)
    ; xxx?xxxx = Convertible Top Front Lock Switch (F172)
    ; xx?xxxxx = Switch Point for Bow UP
    ; x?xxxxxx = Switch Point for Bow OPEN
    ; ?xxxxxxx = Switch Point for Bow DEAD CENTER
    001,3,Switches &&,Positions II,See Label File
    ; xx--xxx? = Compartment Cover Open Position Switch (F201)
    ; xx--xx?x = Left Convertible Top Compartment Cover Switch (F290)
    ; xx--x?xx = Convertible Top Compartment Latch Switch UNLOCK (F293)
    ; xx--?xxx = Compartment Cover Locked Right Switch 1 (F200)
    ; ?x--xxxx = Convertible Top Compartment Encolsure Position Switch (F292)
    001,4,Top Frame,Position (G356),Range: 0.0...255.0
    002,1,Vehicle Speed,,Range: 0.0...254.0 km/h\n\n255.0 km/h = Invalid
    002,2,Voltage,(Terminal 30),Range: 6.0...18.0 V\nSpecification: 10.6/11.5...16.0 V
    002,3,Rear Lid,Contact Switch,Range: Lid Open/Lid Closed
    002,4,Window Regulator,Operation,See Label File
    ; xxxxxxx1 = Window Regulator Driver: Up
    ; xxxxxx1x = Window Regulator Driver: Down
    ; xxxxx1xx = Window Regulator Passenger: Up
    ; xxxx1xxx = Window Regulator Passenger: Down
    ; xxx1xxxx = Window Regulator Rear Left: Up
    ; xx1xxxxx = Window Regulator Rear Left: Down
    ; x1xxxxxx = Window Regulator Rear Right: Up
    ; 1xxxxxxx = Window Regulator Rear Right: Down
    003,0,Window Positions
    003,1,Window Position,Driver's Door,Range: 0.0...100.0
    003,2,Window Position,Passenger Door,Range: 0.0...100.0
    003,3,Window Position,Rear Left Door,Range: 0.0...100.0
    003,4,Window Position,Rear Right Door,Range: 0.0...100.0
    004,1,Operation,Requirements,See Label File
    ; 1x-xx-xx = Surroundings NOT OK
    ; x1-xx-xx = End Position NOT OK
    ; xx-1x-xx = Request: Lock Cylinder Closed
    ; xx-x1-xx = Request: Lock Cylinder Open
    ; xx-xx-1x = Rear Lid Locked
    ; xx-xx-x1 = Request: Rear Lid Locking
    004,2,Conv. Top Disabl.,due Runtime Error,Range: Yes/No
    004,3,Status,Terminal 15,Range: ON/OFF
    004,4,Status,Terminal 87,Range: ON/OFF
    005,0,Rear Window Heating
    005,1,Rear Window,Heating,Range: ON/OFF
    005,2,Rear Window,Heater Relay,Range: ON/OFF
    006,0,Convertible Top Status (At Fault)
    006,1,Convertible Top,Control Switch,Range: Open/Closed/Not Oper./Not OK
    006,2,Switches &&,Positions I,See Label File
    006,3,Switches &&,Positions II,See Label File
    ; xx--x?xx = Convertible Top COmpartment Latch Switch UNLOCK (F293)
    006,4,Top Frame,Position (G356),Range: 0.0...255.0
    007,0,Convertible Top Status (Before Fault - While OK)
    007,1,Convertible Top,Control Switch,Range: Open/Closed/Not Oper./Not OK
    007,2,Switches &&,Positions I,See Label File
    007,3,Switches &&,Positions II,See Label File
    007,4,Top Frame,Position (G356),Range: 0.0...255.0
    Mar 2010
    6
    does anyone know where the rooftop lock switch is,this is what is coming up on the diagnostic check as an an active fault.
    Dec 2008
    133
    Quote Originally Posted by cvro4 View Post
    What is the actual vagcom/vcds fault ?? is it implausible position and what is the actual error code.
    if its implausible position, then you need to reset the values of all the switches with the adaptation channel 1 , and then manual open the roof with the key and perform a manual open and then close procedure, this will tell the switches what values they can goto when opening and closing the roof
    I know you have said you have done it, but did you set the values to zero with vagcom first ??
    Mar 2010
    6
    ok,i think it will have to go to a specialist,any recommendations?bedfordshire area
    Mar 2010
    6
    Quote Originally Posted by blackpool1974 View Post
    hi,apparently the code is 1997,saying open top lock switch,locked or without voltage and switch position,i think this fault developed after the battery was changed,does this help?thanks
    Jul 2010
    Hi Guys,
    Wonder if anyone can help :=)... by girlfriends sister is in a bit of money mess and needs to sell her audi A4 S4 convertable, problem is, the roof doesnt work properly which sort of kills the value of the car. I have scanned it with a friends VAG and found :
    VAG-COM Version: Release 704.1
    Address 26: Auto Roof
    Control Module Part Number: 8H0 959 255
    Component and/or Version: VSG B6 CABRIO 6286
    Software Coding: 0000000
    Work Shop Code: WSC 00652
    1 Fault Found:
    02000 - Switch Position
    008 - Implausible Signal
    The roof starts to fold up, boot opens and then it stops :-( .. From what I can see it looks like Rear lid contact switch is always showing closed even when its open .... could this cause this? anyone know where it is?
    Many thanks
    mark
    Dec 2008
    133
    Have you done the full manual reset ??
    Whereabouts are you ??
    Jul 2010
    Hi, yes - multiple resets :-(. Liverpool (UK). Any ideas?
    Dec 2008
    133
    I think what you need to do is, when you do a manual open and are using the manual key on the rear lid, whilst someone is holding the back window vertical, unlock and lock the rear lid a few times and see if vagcom recognises you unlocking it
    or do a manual opening and lock the roof in the boot, then try the open button.
    Please Help me!! i'm new
    Sep 2010
    Essex, Rainham
    HI Guys
    I got a 2004 A4 convertible 1.8t
    and to day my roof made a bang sound then stoped, i lost my hand book and had to try and close it, when i turned the car off the roof floped down and i managed to fold it back and drive it in the open mode, once home i located the key to do this so i locked it and closed it a few times but when i use the switch it, it only moves to the close part then stops the boot cover stays open or sometimes it opens at the wrong time its as if the roff has no idea of where to should be or what it should be doing? i been looking all over the net but no answers to what the problem, io called audi and they said its 150 an hour, and to be fair i cant be spending that on a fault that i am not going to get fixed coz they will want more, then after reading a few bits on this site i see there is a lot of things going on with the roofs, so HELP!!! i called the RAc but the guy saiud they dont have the right things for it and said go to audi or find someone with the plugin who can code this fault,im in the romford area but travel up and down to the bedford area so if anyone can help me out im happy to even pay but not loads as im no rich man cost the engine went the other week and set me back 3500, so moneys short, but is there a reset,
    Sep 2010
    I know this is an old thread, but I'm facing the same problem with the same codes 02000 - Switch Position
    and 008 - Implausible Signal. I've manually folded the top down and up, but the same error occurs. The boot cover doesn't doesn't open when it's supposed to. Then the top just closes itself again, but fails to lock closed.
    I have a vag-com, but don't know how to "reset the values of all the switches with the adaptation channel 1". Could you offer some specific instructions on doing that? I can access the controller with the vag-com, I click Adaptation, enter "01" as channel, click "Read". I have "1" as "Stored Value". Thanks.
    Jul 2011
    I had same exact problem 2000 Switch position fault ocurred first but after clearing with Ross Tech Vag, didn't return and the roof retracts all the way to rear lid compartment ...then stalls. The rear lid doesn't seem to want to power up and continue the opening sequence. I'm hesitant to blame this on the ECU bulletin ( inclined fault trigger requires B software upgrade) if its either the F201 Rear Lid Compartment switch thats fouled or a hydraulic pump problem. Two questions for anyone before I drop $350 on the ECU :
    1) Does anyone know how to measure the F201 sensor? It doesn't show anywhere on the Vag Com diagnostics and I cannot locate it from any Audi bulletin precisely. Somewhere in the rear pillar/roof frame right side.
    2) Would hydraulic pump work to pull the roof up off front locks, and retract all the way back to lid compartment but not be strong enough to lift the lid ? The Ross Tech wikis nor anything I've read instructs on how to check Hydraulic pump efficacy. Why would it pull the roof pistons and not the lid ?
    The dealer wanted $2500 to fix this. Replace the ECU plus the front lid latching motor ( which wasn't broken, the screws were just loose so it wouldn't screw down...I took it off the hood and tightened screws....perfect !)
    So $350 is better than $2500 but I just want to make sure a simple switch f201 realignment won't do the trick first. Problem is..I can't find the darn thing or diagnose it!!!
    Jul 2011
    Sorry to butt in here but i didn't think that this was worth a new thread, i just wanted to know the name of something. the shelf in the boot that needs to be down for the roof to be open, what it's called? need a replacement but i can't find a unit because i have no idea of the name.
    many thanks and sorry.
    david
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    311
    All be very careful to blame sensors when the roof is not functioning (even though they do come up on vagcom). It is useful to note that an implausible signal means that the control unit is receiving a signal that it cannot believe and does not necessarily mean the switch is faulty. For instance if the roof motor is to fail during operation, the ecu will think to itself that the motor is still functioning and will hence probably think a microswitch is giving an "implausible" signal. Implausible signal fault codes are also generated when things are out of sync.
    I have put a guide together on how to clean the communtator on the hydraulic pump motor (which was the fault in my car)
    Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
