AH FabricationsBadger5
Results 1 to 16 of 16
    iyrix's Avatar
    Mar 2010
    427
    Seat Back Panel - Broken
    Hi Guys,
    Got a broken back on my drivers seat. Looks like the bottom clips are broken, but im not too sure how i can take it off to fix. These are the pictures i've managed to take. Can any let me know how i can remove this and fix it?
    This is looking up a the connections
    Graham
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    The top has sprung clips so should pull out - although may be safer to use a trim-priser.
    I think you can see the 3 clips at the top of the 2nd picture.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    hi there
    I had the same problem and you can buy a seat repair kit from audi for about 8 - 10 from memory - theres a how to with photos somewhere on the forum. il have a dig about
    iyrix's Avatar
    Mar 2010
    427
    Quote Originally Posted by Woorlord View Post
    I've tried but i was worreid about making it worse. Will have another go this weekend.
    Quote Originally Posted by swarcup View Post
    hi there
    Thanks for that, i will check with Audi.
    If you could dig that out it would be great! I couldn't seem to find it.
    CHeers
    Graham
    Audi A4 TDi 130 Sport
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    hi there
    Really , i was not told they had one, my daughter has made a bit of a mess with mine too when she sits in the back.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by Turkster View Post
    I have this problem too, at the moment if I slide the passenger seat forward a bit her feet don't reach the seat back. But this is only a temporary fix lol!
    What does the repair kit consist of?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    The kit consists of 2 metal clips that fit into the slot near the bottom of the seat back and hook over the rear of the actual seat. Simply they just replace the plastic ones that are moulded onto the seat back itself, the plastic ones tend to snap off when you push back on the seat trying to remove something from your pocket. I repaired mine from a how to with photos but i have searched and searched but cannot find it now. will keep trying though.
    found this although not the one im after http://www.audi-sport.net/vb/showthr...highlight=seat
    iyrix's Avatar
    Mar 2010
    427
    Hi Guys,
    Been to Audi this morning to order the bits that are needed.
    They do a fixing kit (ithink this is the right bits). It includes 2 clips and a velcro strip.
    The 2 clips will hopefully attach to the seat back and then pop into the back of the seat. Will let you know how i get on...
    G.
    iyrix's Avatar
    Mar 2010
    427
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    Thats the one, the velcro strip is self adhesive and although there are no instructions i fitted mine to the seat where the new clip will sit to stop any rattling noises and scratching of the seat.
    iyrix's Avatar
    Mar 2010
    427
    When i get mine i will take pictures so everyone else knows. Seems to be a recuring problem!
    G.
    Mar 2008
    Dorset
    13,856
    The only problem with mine is that the plastic seat back gets scuffed by the underneath of my daughters feet!
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    on closer inspection you will probably find that the lumbar support has broken causing the seat back to be pushed out breaking the securing clips. i have got the same problem with mine but just haven't had time to order the parts with PJMSpeedy to fix it. you can tell if the lumbar support has broken by placing your hand on the lowest cushion/lumbar part of the seat and if it is very lose/slack and not taut it is broken, luckily its a very easy fix...
    have a look at this diy guide: Lumbar Support Replacement
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    iyrix's Avatar
    Mar 2010
    427
    Quote Originally Posted by 1210tech View Post
    After looking again this morning it looks like my lumbar support has broken. I've checked on ETKA and the part is just over 50 including VAT. So this will need doing before the clips are replaced.
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    Quote Originally Posted by iyrix View Post
    yeah, PJMSpeedy quoted me about 53 plus p&p, he will be able to get you one too, drop him a PM
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    I've just had this happen to me.
    On taking the back of the seat off the lumbar support is broken as well.
    Have ordered the seat repair clips and new lumbar support from TPS, they should be here in the morning for me to fit them using THIS excellent link posted above.
    HERE is the guide for the repair kit.
    Part numbers:
    Lumbar support: 8E0-881-891
    Seat repair kit: 8E0-898-035
    Thanks to everyone
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
