EM TuningChris Nott
Thread: power lose
    Mar 2010
    7
    power lose
    right my 1.8t (190) q has lost a lot of power through the gears now the engine management light is now on! HELP please,
    amy ideas what it is? i was thinking the re-circ valve as had same sort of problem on my 1.8t golf, any help cheers,
    A4 nut's Avatar
    wolverhampton
    352
    You need to vag-com it, It could be any thing ie air mass ,pcv valve they are just two ive had that gave me loss of power you wont find out till you do.
    Hope the people that took me DIE
    Mar 2010
    7
    gotta mate vag-com'in it tomorrow, another quick question, will my forge 007p off my golf fit on my a4?
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Yes it'll fit!
    Aug 2009
    833
    Coil pack is first check imo.
    I also had to replace some vac pipes recently .
    Mar 2010
    7
    sorted , faulty sensor on air flow, now running a treat!
