Sky InsuranceChris Nott
    Nov 2007
    Across the pond in the Colonies
    10
    Wipers Not parking
    Yesterday while driving in the rain using the intermittent feature, my wipers suddenly decided that the park position was almost straight vertical! I thought I heard a click as it happened but can't be certain. As we continued on our merry way they began getting closer and closer to the correct position and currently are almost all the way back. Is there anything I can do, adjust, kick?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Maybe the wiper mechanism seizing up? Or a relay fault?
    Nov 2007
    10
    Actually I found this link that leads to others that look helpful. Unfortunately I also see that the problem is not unique since it's been approached by several on several forums.
    http://forums.audiworld.com/showthread.php?t=2777199
    basspower's Avatar
    64
    i has this prob turned out i needed a new wiper motor.
    polar's Avatar
    Gosport, Hampshire
    86
    Had problem last week. My wipers stop in the wrong position because the motor cut out due the wiper linkage seizing up. A very common problem.
    If you can get the wipers moving get some "Plus Gas" Penetrating lubricant. You can use WD40 it is not as good at penetrating but will still work.
    Take off the black cover, covering the battery and wiper mechanism. Using the Supplied red straw that comes with the spray. soak the linkage ends. Not just the linkaqe parts that attach to the wipers but also the connections behind.
    If the wipers are very stiff then give a helping hand by lightly helping the wipers. They will free up and move correctly.
    Mine took two days to get moving properly and now after a good soaking every day the blades are working correctly even on full speed.
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    well ive just replaced the linkage, all working spot on now but what a **** job to do,
    and any one know how much the plastic scuttle panel trims are, i got a bit frustrated with it lol
