Chris NottSky Insurance
Results 1 to 9 of 9
Thread: A Few faults
    defsix's Avatar
    149
    A Few faults
    Just looking for a bit of help on the faults that i've logged, here's the logged faults;
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AC
    Component: A4 Klimaautomat 1323
    Coding: 00000
    Shop #: WSC 63251
    2 Faults Found:
    00819 - High Pressure Sensor (G65)
    30-00 - Open or Short to Plus
    01336 - Data Bus for Comfort System
    80-00 - Single-Wire Operation
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 00401
    Shop #: WSC 00183
    WAUZZZ8E74A177160 AUZ6Z0C0428500
    1 Fault Found:
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 BD
    Component: Komfortgert TBF 1511
    Coding: 07163
    Shop #: WSC 63251
    Part No: 8E2959802B
    Component: Trsteuer.FS BRM 0003
    Part No: 8E2959801B
    Component: Trsteuer.BF BRM 0003
    4 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 M
    Component: symphony II NP2 0400
    Coding: 01201
    Shop #: WSC 66048
    2 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
    49-00 - No Communications
    00466 - Control Module for Steering Column Electronics (J527)
    A few faults i have noticed are A/C stuck on ECo ( needs gassing i think ) OneClick up/down didn't always work ( is working correctly now) . My ipod connected to my denison300 has decided to start skipping when driving on rough roads.
    Any help is much appreciated .
    pjmspeedy's Avatar
    Dude, what's mine say ?
    Apr 2008
    North West
    1,057
    The best thing to do is check the codes on the RossTech wiki site for possible solutions.
    Good luck and let us know how you get on. Interesting the coding for your aircon
    unit is all 00000
    Audi A4 1.8T Sport Cabriolet-Full black leather(Electric & heated),RNS-E,BOSE, OEM Bluetooth,RS4 Mirrors,RS4 FBMFSW,RS4 Pedals,RS4 RARB,Cruise Control,B7 Rear Lights,Ally Inlays,18" RS6 Alloys,HID's/Auto lights with dimming rear view mirror,Coming home lights,Ambient light pack & Rear parking sensors.
    For all your VAG OEM PARTS send me a PM or e-mail me at vagoemparts@ymail.com
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Clear all DTC's and see what pop's again - saves on a wild goose chase and narrows faults down to what's happening now!
    Some of these errors look like items have been removed and, car ignition was switched on, hence some of the" no" communication errors.
    Coding for A/C set to 00000 is fine.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The fault in the pressure sensor on the condenser would explain why the econ light is on. This can be changed with no loss of refrigerant so I've read on here.
    defsix's Avatar
    149
    So I checked through the Ross Wiki, I am a little confused about the air con problem, is it the switch ( is this behind the nearside headlight ? ) or is it low pressure ( needs gassing ) . As for the single wire operation , can anyone explain this to me in further detail, is it a problem or bad coding of some part ( I am running Canadian cluster for DRL's ) . And to the last problems.. the CCM, this appears to be working now , will log faults next week ( the last log has been from the last month ) , i will lift the carpets and check the ccm for corrosion as i think this may be the problem... intermittent connection.
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    Quote Originally Posted by defsix View Post
    Some A/C info here on your "G65" error.....>>Link Here<<
    defsix's Avatar
    149
    Thanks , that was the post i was looking for, however mine has short to plus, this is short to ground , does it matter ?
    mattyboyc's Avatar
    Sep 2009
    1,223
    Gaurnteed once you change the sensor all will be ok, 38+vat from tps, simply unscrew with a 17mm spanner,screw new one in, job done all this can be done with no loss of gas, i did mine last week.
    A4 AVANT 1.9TDI 130 SPORT:
    18" RS6'S//TWIN EXHAUST//ALLARD EGR DELETE//AERO WIPERS//B7 KEYS & ENGINE COVERS//BLACK OPTICS //FRONT & REAR S-LINE BUMPERS//TAILGATE SPOILER//S4 HEADLIGHTS,GRILLS & DOOR BLADES//RS4 RARB & PEDALS//FRONT,REAR & FOOTWELL AMBIENT LIGHTING//PUDDLE LIGHTS//FAN JETS//MEDIA SYSTEM//T.V//7" HEADREST MONITORS//REAR BLINDS//REVERSE CAMERA// CRUISE & DIS
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    Now you've made me get the circuits out to check the sensor connections!
    G65 sensor has three wires,
    Pin 1: 0v (Chassis) [brown/white]
    Pin 2: Signal to A/C Control Head unit [brown/blue]
    Pin 3: +12v [grey/red]
    As I recall from the workshop manuals, the Pin 2 signal back to the A/C control unit is a pulse width modulated (digital) signal depending on the pressure sensed.
    So the detected fault states can be continuously grounded to 0v (short to ground), or continuously tied up to 12v (Short to plus).
    Any of these fault states could be a duff sensor.
