Volks AutosChris Nott
    Oct 2005
    Scotland
    7
    B6 Issues Anyone Help ?
    Ok I have just purchased a Audi A4 Estate SE (130) 2002
    Prob 1 - The rear boot now no longer opens, opened when I veiwed the car how do I get into the boot from the inside, How do you remove the panel (4 Screws) or does tailgate need to be open to remove this.
    Prob 2 - The fan seems to kick on as soon as the ignition is on is this correct should it be running at all times
    Scotty
    Dec 2009
    Chester
    19
    There is a panel on the door with a twist lock undo and there is a plastic pull ring to open from inside.
