glove box removeal
scott b
Active Member
Warrington, Warrington, United Kingdom
will be fitting a handsfree kit (kenwood bluetooth) as ive just fitted a kenwood headunit, but will be needing to mount the unit behind the glove box
ive done a search and not much has come up, apart from 1 saying thers 6 T20 screws
can anyone comfirm this and if this is corect will the glove box just pull out
will also be putting a USB input in the glove box for the headunit and more than likely another 12 volt input socket
cheers
yep just 6 sc but put your knees under it so it dont snap when your undoing the last few screws mate
If you open the glovebox, from memory there are about 3 screws on top, and two (maybe 3) hidden underneath. Apart from that it's just a case of popping the side from the end of the dashboard so you can see what you're doing.
4K
933
11
8K
2K
